Switch from AC to Non-AC Heater box #370003
07/08/09 01:45 PM
07/08/09 01:45 PM
St Louis, MO, USA
srunge55 Offline OP
srunge55  Offline OP
St Louis, MO, USA
I have a 69 GTX with AC. I have the box out and don't want to reinstall the AC. Will a non AC box bolt right in? I know I will have some holes to cover in the firewall but is there anything else to consider?
Thanks,
Steve
Re: Switch from AC to Non-AC Heater box [Re: srunge55] #370004
07/08/09 01:52 PM
07/08/09 01:52 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Nope, firewall is different, You'll have to drill new holes I think. Then getting all the vents correct could take some engineering
Coming soon!!!!
Re: Switch from AC to Non-AC Heater box [Re: Mr.Yuck] #370005
07/08/09 07:15 PM
07/08/09 07:15 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
You can always buy the Mojave heater from Summit. Hang it right above your console behind the dash. I made one for my 70 Charger and it was blowing air at 3 speeds, and had the optional vent on the side to hook up to the dash defrost vents. I think it was like $120. Weighed 14lbs when it was filled with water. A heck of allot better than the 80lb factory unit and your firewall has allot more space. I opted to hang all my MSD ignition on the passenger side firewall and an updated fusebox
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
