904 trans problem #369939
07/08/09 11:48 AM
07/08/09 11:48 AM
Ridgeland, WI, 54763
Curt57 Offline OP
Curt57  Offline OP
Just rebuilt a 904 for a 71 scamp. I installed a B&M shift kit. The trans is going into reverse fine. But is slipping in forward gears to the point it hardly pulls itself. Fluid is starting to smell burned. Any help would be great. HELP
Re: 904 trans problem [Re: Curt57] #369940
07/08/09 11:53 AM
07/08/09 11:53 AM
Iowa
burdar Online work
Owen's Dad
burdar  Online Work
Owen's Dad
Iowa
Are you sure you got all the O rings installed? I had a friends 904 on the trans dyno and it slipped really bad. He forgot to install one of the O rings on the input shaft.
Re: 904 trans problem [Re: burdar] #369941
07/08/09 12:33 PM
07/08/09 12:33 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
Can you tell wich one ? for info,...
Re: 904 trans problem [Re: Wedgeman] #369942
07/08/09 01:02 PM
07/08/09 01:02 PM
Curt57 Offline OP
Curt57  Offline OP
I'M quite sure. I have done a few of these. But I could have made a mistake. Is there a way to tell before pulling the trans? THANKS
Re: 904 trans problem [Re: Wedgeman] #369943
07/08/09 01:03 PM
07/08/09 01:03 PM
Iowa
burdar Online work
Owen's Dad
burdar  Online Work
Owen's Dad
Iowa
It was years ago...but it was a small one on the input shaft.
Does anyone have an expanded drawing of the 904?
Re: 904 trans problem [Re: Curt57] #369944
07/08/09 03:07 PM
07/08/09 03:07 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Sounds like you have major leakage at the rear clutch, remove the valve body and do an air check on the rear clutch passage. (good idea to do this at each rebuild)
Re: 904 trans problem [Re: John_Kunkel] #369945
07/08/09 04:11 PM
07/08/09 04:11 PM
Curt57 Offline OP
Curt57  Offline OP
THANKS
