rear housing paint #369878
07/08/09 09:12 AM
07/08/09 09:12 AM
Winnipeg,Manitoba
cudablues Offline OP
Winnipeg,Manitoba
Whats a good paint to use on my rear end housing?
Re: rear housing paint [Re: cudablues] #369879
07/08/09 11:12 AM
07/08/09 11:12 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
I use either Rustoleum or Plasti-kote's satin black.
Ride eternal, shiny and chrome
Re: rear housing paint [Re: cudablues] #369880
07/08/09 11:21 AM
07/08/09 11:21 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Chassis black from Eastwood? That's what I used.
Re: rear housing paint [Re: Challenger 1] #369881
07/08/09 11:22 AM
07/08/09 11:22 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Me too, with great results.. (tried thier Extreme chassis black on the last one actually)
Re: rear housing paint [Re: OzHemi] #369882
07/08/09 11:25 AM
07/08/09 11:25 AM
Cincinnati, Ohio
Cincinnati, Ohio
I have some of the newer stuff too, just have not used it yet.
The old stuff, you had to paint it all at once, because recoating would cause it to lift. But is very durable paint.
Re: rear housing paint [Re: Challenger 1] #369883
07/08/09 11:31 AM
07/08/09 11:31 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
I've been using the Extreme stuff lately while building the Torana.. I've recoated a couple of things and it's stuck down hard. (..lower rear control arms, upper and lower fronts, etc..) it takes longer to cure then the 'normal' chassis black, but wow does it go off hard and durable!
I tried it when it came out since I was ordering some cans of the normal stuff and thought would try one of the super-duper ones, being on sale at the time
I painted a diff housing with the Extreme, and had forgot to weld a tab on for the rear brake line mount and had to basically grind the paint to get it off in a spot to weld...it really stays down.
Re: rear housing paint [Re: OzHemi] #369884
07/08/09 10:46 PM
07/08/09 10:46 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
Extreme?
Re: rear housing paint [Re: 05dakota] #369885
07/08/09 10:50 PM
07/08/09 10:50 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Re: rear housing paint [Re: cudablues] #369886
07/08/09 11:07 PM
07/08/09 11:07 PM
Windsor, Ontario
P
project74 Offline
project74  Offline
P
Windsor, Ontario
Just painted my diff this past weekend with Rustoleum Hard Hat industrial enamel. Came out really nice and is super tough to boot.
1970 Fury III, 318, 4 dr hardtop, aka "The Fridge"
Re: rear housing paint [Re: project74] #369887
07/09/09 08:51 AM
07/09/09 08:51 AM
Winnipeg,Manitoba
Winnipeg,Manitoba
Thanks for the replys.Ill check both out.
