Trunk finish #369789
07/08/09 04:24 AM
07/08/09 04:24 AM
Va (for now)
FY1TA & 65 Wedge Offline OP
mopar addict
mopar addict
Va (for now)
On my 22k mile Survivor T/A, moisture must have collected underneath the trunk mat. From the pictures you can see how I have some rust/corrosion.
I want to stop this and protect the metal, but how would you seal and refinish to give a near factory look?
Also will post some detail of the trunk mat.
Re: Trunk finish [Re: FY1TA & 65 Wedge] #369790
07/08/09 04:24 AM
07/08/09 04:24 AM
Va (for now)
mopar addict
mopar addict
Va (for now)
pic 2
Re: Trunk finish [Re: FY1TA & 65 Wedge] #369791
07/08/09 04:26 AM
07/08/09 04:26 AM
Va (for now)
mopar addict
mopar addict
Va (for now)
pic 3
Re: Trunk finish [Re: FY1TA & 65 Wedge] #369792
07/08/09 04:27 AM
07/08/09 04:27 AM
Va (for now)
mopar addict
mopar addict
Va (for now)
pic 4
Re: Trunk finish [Re: FY1TA & 65 Wedge] #369793
07/08/09 04:27 AM
07/08/09 04:27 AM
Va (for now)
mopar addict
mopar addict
Va (for now)
pic 5
Re: Trunk finish [Re: FY1TA & 65 Wedge] #369794
07/08/09 11:11 AM
07/08/09 11:11 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
sander , possibly the indents with a small blaster, epoxy prime and repaint
Re: Trunk finish [Re: FY1TA & 65 Wedge] #369795
07/08/09 11:19 AM
07/08/09 11:19 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
My guess is that most people would say to leave it alone if it is truely a "survivor" It's only that way once.
Re: Trunk finish [Re: FY1TA & 65 Wedge] #369796
07/08/09 06:02 PM
07/08/09 06:02 PM
SE Pa.
LimeliteAero Offline
SE Pa.
Im not sure if anyone else sells it but Eastwood sells a clear rust encapsulator.
it isnt clear after if reacts with the rust. it dries to a greyish finish. The rust will not progress once its sealed. then you dont have to worry about it until you begin a resto or you decide to sell.
Id loved to hear what can be done to clean up the mat, I have the same issues with my original superbird mat.
Re: Trunk finish [Re: burdar] #369797
07/08/09 06:28 PM
07/08/09 06:28 PM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
I'd assume that as long as the car is being properly stored now that you should not have any additional issues with rust spreading further.
BTW, you now need to update your signature to reflect the fact that you now have a 22K mile survivor instead of a 21K survivor.
Re: Trunk finish [Re: rss] #369798
07/08/09 07:53 PM
07/08/09 07:53 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Anyone ever try the household produvt CLR on something like that mat? Think I would try a small area as it removes rust stains left from high iron levels found in well water here in FL
Re: Trunk finish [Re: rrunner] #369799
07/08/09 08:19 PM
07/08/09 08:19 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
I have used CLR and a scrub brush - it gets a lot of the rust stain off of trunk mats. As for the trunk floor, leave the mat out whenever the car is parked for awhile and leave it as is. If I was looking to buy a survivor I would rather see what you have in the trunk than a primered-up, doctored up trunk and other areas.
Re: Trunk finish [Re: FY1TA & 65 Wedge] #369800
07/09/09 08:19 AM
07/09/09 08:19 AM
cataclysm80 Offline
cataclysm80  Offline
You might consider using a product like Evaporust. It would sit down in the trunk grooves, or you could soak a rag in it and lay the rag over the surface. With a little time, that should get the rust gone. Then you could clear over it to keep it from rusting, or scuff and repaint inside the trunk.
Evaporust shouldn't harm your body plugs or seam sealer. It might help on the trunk mat too.
Tav
Re: Trunk finish [Re: cataclysm80] #369801
07/09/09 09:32 AM
07/09/09 09:32 AM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
The Evaporust is a good idea but thats NOT surface rust. POR 15 has a clear paint but if it was my car , I would leave it alone and store it properly in a very dry area. You could try some heavy junk towels soaked in the Evaporust and lay the towels on the rust for a few days to see if it works.
Re: Trunk finish [Re: THESHAKERPROJECT] #369802
07/09/09 11:24 AM
07/09/09 11:24 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Good old Naval Jelly. Brush it on and let it set, wash it off and all the rust will be gone but not the paint. Spray it with clear if you do not want to repaint.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
