SB Dipstick alternative? #369409
07/07/09 07:02 PM
07/07/09 07:02 PM
Montreal PQ, Canada
74_360_Cuda Offline OP
Montreal PQ, Canada
I broke 2 new dipsticks trying to bend them in order to clear the fuel pump (360, holley fuel pump).
I was considering the flexible distick from Milodon (22060) and I would like to have feedback on them or any other good alternative.
They specify that those are designed for center sump pump... I guess this is the standard configuration for my 360?
Any pictures?
Thanks,
Re: SB Dipstick alternative? [Re: 74_360_Cuda] #369410
07/07/09 10:11 PM
07/07/09 10:11 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I just installed a new dip stick tube in my 408 build. After I drove the tube in I used a propane torch to heat it just above the block and gently bent it to clear the fuel pump. Mine was a mile long and the dip stick hit the baffle in the Milodon pan so I cut the tube and stick to match the ones in my 340. The stick will have to have a new full mark put on it.
Re: SB Dipstick alternative? [Re: justinp61] #369411
07/07/09 10:21 PM
07/07/09 10:21 PM
Montreal PQ, Canada
Montreal PQ, Canada
What brand of dipstick did you use?
Re: SB Dipstick alternative? [Re: 74_360_Cuda] #369412
07/07/09 10:40 PM
07/07/09 10:40 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
It came from Mancini Racing, just the plain steel one.
Re: SB Dipstick alternative? [Re: justinp61] #369413
07/09/09 11:13 PM
07/09/09 11:13 PM
Montreal PQ, Canada
Montreal PQ, Canada
Anyone using the Milodon flex dipstick?
Any Issues?
Pictures?
Thanks,
