1/8th mile conversion #368776
07/07/09 12:25 AM
07/07/09 12:25 AM
Port Mcneill,B.C.Canada
I
Islandcuda Offline OP
I
Hi all, we just had a test and tune session at our local airport for 1/8 mile, we had cement burnout boxes vht and lights for single runs. I ran a 6.48 in the 1/8th, can anyone tell me what that converts to in 1/4 mile. I can,t find last years time slips, thanks Tim
67 cuda new best 1.395 60 10.240 at 128.58mph
Re: 1/8th mile conversion [Re: Islandcuda] #368777
07/07/09 12:33 AM
07/07/09 12:33 AM
iowa
copchaser Offline
copchaser  Offline
iowa
A 6.45 should be a 10.06 and a 6.5 comes out at 10.14 so flip a quarter and you decide.
Re: 1/8th mile conversion [Re: Islandcuda] #368778
07/07/09 12:34 AM
07/07/09 12:34 AM
Bristol, Va
fasteddie Offline
fasteddie  Offline
Bristol, Va
Multiply by 1.58 should be pretty close.
6.48 X 1.58 = 10.24
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
Re: 1/8th mile conversion [Re: fasteddie] #368779
07/07/09 12:40 AM
07/07/09 12:40 AM
I
I
Thanks guys, there were traction issues, I,m just hoping I,m not in the 9,s at real strip as I just don,t want to go there yet, tim
Re: 1/8th mile conversion [Re: fasteddie] #368780
07/07/09 01:41 AM
07/07/09 01:41 AM
pacific northwest
Stroker Scamp Online content
Stroker Scamp  Online Content
pacific northwest
6.48 X 1.58 = 10.24
my 1/8th was a 6.44 with a 10.24 in the 1/4 fwiw
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: 1/8th mile conversion [Re: Islandcuda] #368781
07/07/09 03:35 AM
07/07/09 03:35 AM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
1.59 was the formula i was told to use
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: 1/8th mile conversion [Re: toplescuda] #368782
07/07/09 04:18 AM
07/07/09 04:18 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
What was your MPH?
Re: 1/8th mile conversion [Re: CokeBottleKid] #368783
07/07/09 08:14 AM
07/07/09 08:14 AM
I
I
We had no mph, this only did times and you had to reset after every run, but we did discover that in the future our local airport will work.
Re: 1/8th mile conversion [Re: Islandcuda] #368784
07/07/09 09:18 AM
07/07/09 09:18 AM
NC
440Jim Offline
440Jim  Offline
NC
Different cars will have different 1/8 to 1/4 ratios. But 1.57-1.59 should cover it, if the car was working properly.
Re: 1/8th mile conversion [Re: Islandcuda] #368785
07/07/09 09:35 AM
07/07/09 09:35 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Every car is different in actual Times for instance mine is 1.575 will be bang on.
I think NHRA uses 1.56 anyhoo NHRA says that at 6.39(or 9.99)for license and cage
Re: 1/8th mile conversion [Re: Dodgem] #368786
07/07/09 11:02 PM
07/07/09 11:02 PM
Russiaville, IN
mopar376d Offline
mopar376d  Offline
Russiaville, IN
I just ran 10.59 (1/4) & 6.70 (1/8th)
6.70 * 1.58 = 10.586
Why does divorce cost so much? Because it is worth it!!!!!
Re: 1/8th mile conversion [Re: mopar376d] #368787
07/07/09 11:19 PM
07/07/09 11:19 PM
Oak Harbor, WA
W
Wicked49670dart Offline
W
Oak Harbor, WA
I ran 6.42 1/8, 10.22 1/4, 1.41 60ft
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
Re: 1/8th mile conversion [Re: Wicked49670dart] #368788
07/08/09 08:18 AM
07/08/09 08:18 AM
Swamps of South Jersey.
W
wildcargo Offline
wildcargo  Offline
W
mine is --- 1/8 6.388 107.40 --- 1/4 10.082 132.02
Bud www.wildcar-go.itgo.com
64 DODGE
60' 1.433,
1/8 6.38 at 107.4,
1/4 10.08 at 132.02
foot brake, leaf springs
Re: 1/8th mile conversion [Re: wildcargo] #368789
07/08/09 08:22 AM
07/08/09 08:22 AM
I
I
I should be okay then unless there is a tail wind, thanks tim
Re: 1/8th mile conversion [Re: Islandcuda] #368790
07/08/09 11:03 AM
07/08/09 11:03 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
10.15-10.25
Re: 1/8th mile conversion [Re: 440Jim] #368791
07/08/09 11:14 AM
07/08/09 11:14 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
wouldn't it also depend on gearing??? or is that strictly set up for 1/4 mile cars that run 1/8's Some of those 1/8 mile cars have such high gears I doubt they'd calculate out w/ that.
Coming soon!!!!
Re: 1/8th mile conversion [Re: Mr.Yuck] #368792
07/08/09 11:53 AM
07/08/09 11:53 AM
Loudonville, Ohio
nitrojoe Offline
nitrojoe  Offline
Loudonville, Ohio
swingin is right its all about they way you have your car set up. If you have it geared where its making power on the top end your going to be on the slow side 1/8th mile wise, if you have the valves set for low end power, well your going to be fast on 1/8th mile, gearing, valve setting and others will play a big roll on how fast you can go in 1/8th mile.
My roadster went 9.20's all the time on quarter mile, but when i went to Pacemakers i was running 5.80's and 5.90's which is in the 8's so........
Just my 2 cents
Nitro Joe Jackson
Re: 1/8th mile conversion [Re: nitrojoe] #368793
07/08/09 06:46 PM
07/08/09 06:46 PM
British Columbia
toddd Offline
toddd  Offline
British Columbia
Here's a vid I found of Tims' car, from the past weekend.
http://www.youtube.com/watch?v=rSS4NGK-lCs
Re: 1/8th mile conversion [Re: toddd] #368794
07/08/09 08:25 PM
07/08/09 08:25 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
According to the 1.58 theory a 6.19 shows 9.78 and I ran 9.85 so its not too far off.
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
