'65 727 Shift Points #368745
07/06/09 10:03 PM
07/06/09 10:03 PM
San Gabriel, CA 91775
rexus31 Offline OP
rexus31  Offline OP
Under normal acceleration, at what MPH should a '65 727 shift? I tried looking in the Service Manual but could not find this info.
2007 Dodge Charger R/T, Road and Track Performance Group, Steel Blue 1965 Chrysler 300 Convertible, 383 4V, 727TF, Factory Air, Spanish Red 1964 Pontiac GTO, Tri-Power, 4 Speed, Grenadier Red "What ain't no country I ever heard of. They speak English in What?" - Jules Winnfield
Re: '65 727 Shift Points [Re: rexus31] #368746
07/06/09 10:18 PM
07/06/09 10:18 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
What gear is in the vehicle ?
Normal accel ? ... 1/2 throttle ? ... lite throttle?
Re: '65 727 Shift Points [Re: dOc !] #368747
07/06/09 10:24 PM
07/06/09 10:24 PM
rexus31 Offline OP
rexus31  Offline OP
3:23 rear. Normal driving, 1/4-1/2 throttle.
Re: '65 727 Shift Points [Re: rexus31] #368748
07/06/09 10:27 PM
07/06/09 10:27 PM
minimum throttle upshift ~18 & ~28
Re: '65 727 Shift Points [Re: rexus31] #368749
07/06/09 10:36 PM
07/06/09 10:36 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
What are YOU seeing for shift-points? .. THIS would also depend if you have your throttle-pressure linkage set for max travel.
Re: '65 727 Shift Points [Re: dOc !] #368750
07/06/09 10:42 PM
07/06/09 10:42 PM
rexus31 Offline OP
rexus31  Offline OP
Stock shift points.
Re: '65 727 Shift Points [Re: rexus31] #368751
07/07/09 05:22 PM
07/07/09 05:22 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
With light throttle and 3.23 gears the 1-2 shift should occur at 6-13 mph, 2-3 at 11-17 mph.
There are no specs for 1/4 or 1/2 throttle, too subjective.
