Ignition help .. ECU and ballast resistor ?s... #368561
07/06/09 08:50 PM
07/06/09 08:50 PM
Dulles, VA
P
phathemi Offline OP
phathemi  Offline OP
P
Dulles, VA
Hi, my first post, hope I'm doing it right. Mine is a 71 challenger w/383 with electronic igtn. I assume the car was originally a points/condenser ignition but was converted at some point. The car started OK and ran fine, but last week I had dead battery. I jump started the car a couple of times and finally replaced the battery. Now with the new battery, won't fire up. Cranks great, smell fuel, no spark, have 12V at blue wire on resistor w/key in ON position. Wondering if I blew up something while jump starting it. I replaced the coil but didn't help. I want to order an electronic ctrl module (5pin which is what I have), coil resistor (because mine was showing no ohms- short). My questions, 1)How can I get a good brand of ECM –don’t want a cheap Chinese one that works for three weeks, RockAuto sells one by Airtek wonder if it's good.. 2) How do I pick a ECM since mine wasn't stock with electronic ign, are there different ones or are they all set the same? I'm specing one from a 72 charger with a 440 3) Also, on my coil's + term. is a capacitor that mounts to intake manifold, do I need it? Is it an ignition capacitor vs. a condensor? If the car was converted do I even still need that little capacitor? Also-I had read on a thread that if you have a 5 pin ECU that you should have a 4 prong resistor, I only have a 2 prong, but there are not any non-connected wires anywhere, should I worry?
Re: Ignition help .. ECU and ballast resistor ?s... [Re: phathemi] #368562
07/06/09 09:30 PM
07/06/09 09:30 PM
Welcome aboard. A 4 terminal ballast resistor requires a 5 pin ECU but a 2 terminal ballast(what you have) will work w a 5 or a 4 pin ECU. A MP "chrome box" ECU is a very good choice both for reliability and performance but for the money you might grab a parts house one(4 pin if they have em) & get it going. This is a round capacitor connected to the positive primary terminal?. I'd leave it on, helps w voltage surges.
Re: Ignition help .. ECU and ballast resistor ?s... [Re: RapidRobert] #368563
07/07/09 10:25 AM
07/07/09 10:25 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
backwards...
5 pins ecu requires 4 prongs ballast
4 pins ecu can work with both ( 2 and 4 prongs ballast )
5 pins ecu won't work ( at least propperly ) with 2 prongs ballast
Re: Ignition help .. ECU and ballast resistor ?s... [Re: phathemi] #368564
07/07/09 10:31 AM
07/07/09 10:31 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
that could be a radio noise supression condenser. Nothing to worry about. No need for that for ign
Re: Ignition help .. ECU and ballast resistor ?s... [Re: NachoRT74] #368565
07/10/09 11:14 AM
07/10/09 11:14 AM
Dulles, VA
P
phathemi Offline OP
phathemi  Offline OP
P
Dulles, VA
thank you! I don't have a working radio at the moment anyway.
Re: Ignition help .. ECU and ballast resistor ?s... [Re: phathemi] #368566
07/10/09 12:20 PM
07/10/09 12:20 PM
Morningside
AdventurerSport Offline
waaaay out there in left field
Morningside
go to NAPA, part #TP50, lifetime warranty, run 'em on all my Mopars, last a LONG time, 5 pin ECU but the 5th pin is dead, works as a 4pin (universal).
Good luck!
JS
76 Dodge Adventurer Sport Power Wagon W100 318, 727, NP203 Fulltime 4x4 Russet Red
06 Jeep Commander Ltd 4x4, 5.7L Hemi, QuadraDrive II
06 Chrysler 300C AWD 5.7L Hemi
10 Mopar 10 Challenger R/T, #483/500, 5.7L HEMI
10 Jeep Grand Cherokee Ltd 4x4 5.7L HEMI
11 Dodge Ram 1500 LoneStar Quad Cab, 5.7L HEMI, Fulltime 4x4, Deep Cherry Red
16 Jeep Cherokee Limited 3.2L Pentastar V6, 9 Speed Torqueflite, 4x4, Black
Re: Ignition help .. ECU and ballast resistor ?s... [Re: phathemi] #368567
07/10/09 02:00 PM
07/10/09 02:00 PM
IL
71383beep Offline
71383beep  Offline
IL
Ok your post is going all over the place here. Now your getting advice on ECU's but are you still having a starting problem?
If so I think changing the box won't help. I thought that During start power is supplied directly to the + side of the coil from a looped brown wire on the opposite side of the ballast resistor. Once the key is let go the run side powers the box and the - side of the coil.
Look at the tech archives in the electronic ignition section to see this.
'73 GK6 Challenger Rallye - 340 4-Speed
Re: Ignition help .. ECU and ballast resistor ?s... [Re: phathemi] #368568
07/10/09 10:34 PM
07/10/09 10:34 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Capacitor and condenser are interchangeable words. In the olden days, they were condensers. Capacitor is a newer term for the same thing. Even if you don't have a radio, your neighbors and those next to you in traffic would appreciate your using one if they are listening to AM radio.
Craig
Re: Ignition help .. ECU and ballast resistor ?s... [Re: NachoRT74] #368569
07/10/09 10:50 PM
07/10/09 10:50 PM
backwards...
got it
Re: Ignition help .. ECU and ballast resistor ?s... [Re: RapidRobert] #368570
07/20/09 04:06 PM
07/20/09 04:06 PM
Dulles, VA
P
phathemi Offline OP
phathemi  Offline OP
P
Dulles, VA
OK, you guys are gonna kill me, I got the car running, it was the ECU and/or ballast. I bought what was already in the car. 5 wire ECU, 2 prong ballast. I think the 5th wire runs into the harness and doesn't go anywhere. (I had ordered from Rock auto just before adventuresport gave the Napa number-wish I had done that first) During the process I replaced the coil too with an MSD. Now, car sounds great, even starts easier than ever since I've owned it (5 months), so it's probably had an issue since I got it. The problem is the ballast resistor is absolutely lava hot! It's gonna burn out any moment. So, are we back to the, I should have a 4 prong ballast with this ECU? Could it be the new coil being too hot, even though I was told they are universal and that shouldn't matter, maybe thats my problem? I'm ready to buy an MSD ignition and wire from scratch unless you guys think that would be a mistake.
Re: Ignition help .. ECU and ballast resistor ?s... [Re: NachoRT74] #368571
07/20/09 04:35 PM
07/20/09 04:35 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
as stated
get 4 prongs ballast unit and wire it ( green traced red wire ) or get 4 pins ignition module and keep your actual wiring/ballast setup
Re: Ignition help .. ECU and ballast resistor ?s... [Re: phathemi] #368572
07/20/09 04:39 PM
07/20/09 04:39 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
check with msd on what ballast you should be running. MP uses a 1/4 ohm ballast. Some coils don';t need the ballast at all.
Re: Ignition help .. ECU and ballast resistor ?s... [Re: Dougsmopars] #368573
07/20/09 05:13 PM
07/20/09 05:13 PM
TX , NJ , FL
W
WINGCARS_6970 Offline
W
TX , NJ , FL
A brand new ballast resistor will heat up smoke first time .Then after that there good to go.Thats what Ive experienced
1969 Daytona 440 L9B410772 1970 Coronet 500 383 Presently owned 1970 Superbird 440 U 166242 1970 Superbird 440 U 174597 1970 Superbird 440-6 V 179697 1970 Coronet RT 440 U 224126 1968 Road Runner 426 J 134509 1970 Daytona Replica 318 G 178701
