15" Rallye Trim ring question #368335
07/06/09 04:35 PM
07/06/09 04:35 PM
Tenn.
jrwoodjoe Offline OP
Tenn.
I have a set of 15 x 6.5 rallye wheels and would like to know if the trim ring that is on it is considered 15 x 6.5 or 15 x 7. Thinking about going with a polished ring instead of brushed and not sure what I should be looking for as a replacement.
Thanks, Joe
65 Barracuda
70 Challenger
Re: 15" Rallye Trim ring question [Re: jrwoodjoe] #368336
07/06/09 06:23 PM
07/06/09 06:23 PM
Richmond , Virginia
chagjr Offline
chagjr  Offline
Richmond , Virginia
COKER TIRE
F.A.S.T/1969 SUPER BEE/383/AUTO/AVS 11.58 @ 117.98 1.71 60ft mph F.A.S.T Legal
1969 DART SWINGER/340(420CI)/6.52 @ 105.39 1.45 60ft (1/8 mile)10.22 @130.5 (1/4 mile)
Harry
Re: 15" Rallye Trim ring question [Re: jrwoodjoe] #368337
07/06/09 07:51 PM
07/06/09 07:51 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I have 15X6.5 Ralleys on my 71 Challenger, and I used the polished factory 15X7 trim rings, no fit issuses, or oddball gaps
Re: 15" Rallye Trim ring question [Re: DAYCLONA] #368338
07/07/09 03:20 AM
07/07/09 03:20 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Most of the factory 15" Rallye trim rings were actually for the 15x6.5" rim and were 1/2" thinner than the real 15x7" trim rings. The latest MP 15x7 trim rings are 3" deep instead of the 2 1/2" older ones. I don't think the new ones or the original 15x7" trim rings will fit a 15x6.5" Rallye wheel.
15x7" Left and 15x6.5" Right
Re: 15" Rallye Trim ring question [Re: Snoopy] #368339
07/07/09 05:40 AM
07/07/09 05:40 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
That's interesting, I checked the measurement and you were right, I compared a set of "New" 15X7 repro trim rings to the ones I have on the (15X7 trimrings) Challenger (which I purchased in the early 80"s),,,,,there is a 1/2" difference........tonight I'll try fitting a "new" ring on?.....see if it fits?
Re: 15" Rallye Trim ring question [Re: DAYCLONA] #368340
07/07/09 07:51 AM
07/07/09 07:51 AM
Tenn.
Tenn.
Snoopy...you never cease to amaze me with reference pics.
That is really helpful guys. Thank you!
Re: 15" Rallye Trim ring question [Re: jrwoodjoe] #368341
07/07/09 02:29 PM
07/07/09 02:29 PM
Snoopy Offline
Snoopy  Offline
Back in the early 70's, when Chrysler released their 15x6.5" Rallye wheels, they decided to make the trim rings fit the new 15x6.5" Rallye wheels. So they modified the dies that were used to make the 15x7" rings. For some reason, known only to Chrysler, they used the same part numbers that were used for the original 15x7" rings. This came back to bite them on the butt when they decided to reproduce the original 15x7" trim rings. After they made a batch of the new rings, they discovered that they had reproduced the 15x6.5" trim rings instead of the 15x7".
So if you bought a set of 3461043 or 3461222 after 1972 and before 2008, you probably got the 15x6.5" trim rings.
The latest trim rings from Chrysler are the correct 15x7" rings.
Re: 15" Rallye Trim ring question [Re: Snoopy] #368342
07/07/09 03:16 PM
07/07/09 03:16 PM
S.E. Conn
Hoof Hearted Offline
S.E. Conn
Quote: "So if you bought a set of 3461043 or 3461222 after 1972 and before 2008, you probably got the 15x6.5" trim rings."
Ummmm, Not so. I have brand "new" set of 4 15x7 Polished Trim rings with P/N 3461043, made 8/29/06, still in the plastic bags. I temporarily mounted 2 on my 71 SE with 15x7 wheels and they fit perfectly, no gaps. The polished reflective area measures 3" from the inside, and has an overall depth of 3 1/4+". IF I measure the Back Side of the trim ring, it measures 3 3/4" edge to edge.
Again, P/N 3461043, build tag of 8/29/06. Mine are the same as the left ones in Snoopy's pic. I still have 3 6.5" ones in great shape I have no need for(Anyone wants them? )
These have never seen the road and I'd gladly trade them for the correct (for my '71)-Brushed style rings. Yes i'll be at carlilse this weekend and can bring them.
2005 300C Hemi
2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: 15" Rallye Trim ring question [Re: Hoof Hearted] #368343
07/07/09 03:52 PM
07/07/09 03:52 PM
Snoopy Offline
Snoopy  Offline
The trim rings you have are not P/N 3461043.
They are:
P3461043 Trim Ring, Chrome, 15" x 7" Rims
This is a parts tag on a box containing a 15x6.5" Rallye Trim Ring.
Re: 15" Rallye Trim ring question [Re: jrwoodjoe] #368344
07/07/09 04:45 PM
07/07/09 04:45 PM
Snoopy Offline
Snoopy  Offline
I have a set of 15 x 6.5 Rallye wheels and would like to know if the trim ring that is on it is considered 15 x 6.5 or 15 x 7. Thinking about going with a polished ring instead of brushed and not sure what I should be looking for as a replacement.
Thanks, Joe
Chrysler discontinued the 3461043 and 3461222 trim rings in 2005 or 6. There are still a few floating around. I bought a set a couple of months ago.
When they decided to reproduce the 15x7" and screwed up the first batch, they decided to put them in the system.
P5153310 Trim Ring, Deep Dish, Bright Finish, 15" X 6.5" Rallye
Wheel, Road Wheel and Steel Wheel Applications,
Re: 15" Rallye Trim ring question [Re: Snoopy] #368345
07/07/09 05:31 PM
07/07/09 05:31 PM
Detroit, MI.
Mancini Racing Offline
Detroit, MI.
We stock the original Mopar 15 x 7 trim rings in both brushed and chrome.
The correct part numbers are:
P3461043 - Chrome
P3461222 - Brushed
These are the correct dimensions for the 15" Rallye or steel wheel applications and will not fit the 15 X 6.5 wheels
Thanks.
Mancini Racing
800-843-2821
www.manciniracing.com
Proud sponsor of Moparts!
Re: 15" Rallye Trim ring question [Re: Snoopy] #368346
07/07/09 05:35 PM
07/07/09 05:35 PM
S.E. Conn
S.E. Conn
Quote: "The trim rings you have are not P/N 3461043. They are: P3461043 Trim Ring, Chrome, 15" x 7" Rims"
Ok Snoop.
Here's pic one:
2005 300C Hemi
Re: 15" Rallye Trim ring question [Re: Hoof Hearted] #368347
07/07/09 05:36 PM
07/07/09 05:36 PM
S.E. Conn
S.E. Conn
Here's pic Two:
2005 300C Hemi
Re: 15" Rallye Trim ring question [Re: Hoof Hearted] #368348
07/07/09 05:37 PM
07/07/09 05:37 PM
S.E. Conn
S.E. Conn
Here's pic Three :
2005 300C Hemi
Re: 15" Rallye Trim ring question [Re: Hoof Hearted] #368349
07/07/09 05:39 PM
07/07/09 05:39 PM
S.E. Conn
S.E. Conn
HEY Snoop, Here's Pic Four (Don't tell me what I know) Mounted on 15x7" Rallyes, NOT 15x6.5's:
2005 300C Hemi
Re: 15" Rallye Trim ring question [Re: Hoof Hearted] #368350
07/07/09 07:14 PM
07/07/09 07:14 PM
Snoopy Offline
Snoopy  Offline
Hoof Hearted
Yours are not 3461043, they are P3461043. Different part numbers, different parts. I think you should reread my previous posts throughly before you comment.
Re: 15" Rallye Trim ring question [Re: Snoopy] #368351
07/07/09 07:48 PM
07/07/09 07:48 PM
S.E. Conn
S.E. Conn
Hang on the Snoopy, Hang on. I have clearly shown in Exibit One (Above), that my Trim rings are labeled P/N 3461043 NOT P3461043.
Get your Eyes checked.
Anyone out there in Mopartsland smarter than a Visually impaired Guy from the west coast named after a cartoon Dog OR an equally thickheaded guy (with photographic evidence, mind you) from the east coast named after a race horse?
Care to chime in kids?
2005 300C Hemi
Re: 15" Rallye Trim ring question [Re: Hoof Hearted] #368352
07/07/09 08:40 PM
07/07/09 08:40 PM
BDW Online content
BDW  Online Content
I think you stepped in "it" Hoof.
I clearly see a P in your pic.
Re: 15" Rallye Trim ring question [Re: Hoof Hearted] #368353
07/07/09 08:43 PM
07/07/09 08:43 PM
Snoopy Offline
Snoopy  Offline
Hoof in mouth, it sure ain't you?
Take a look at your own picture.
Re: 15" Rallye Trim ring question [Re: Hoof Hearted] #368354
07/07/09 08:58 PM
07/07/09 08:58 PM
CO
Twisted Offline
Twisted  Offline
CO
Ok Snoop.
Here's pic one:
I am kind of in between the coasts and not named after anything but my car. No glasses nor any needed but I see P/N P 3461043. P for performance division reproduction not origonal.
Thank you
Aaron
69 Dodge Polara 4DHT
70 Plymouth Duster
03 Dodge Neon R/T
05 Dodge Grand Caravan SXT
