Re: 61 Dart Phoenix Rear Differential?
[Re: goldchargerdan]
#368168
07/07/09 12:55 PM
07/07/09 12:55 PM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
Because the older rears had the stub hubs.Dr Diff has a kit to swap to new style drums and axles.Most just use a later rear end.Rocky
Chrysler Firepower
#368170
07/07/09 05:08 PM
07/07/09 05:08 PM
Posts: 25,914 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Why do you want to change from the original taper bearings?
#368172
07/07/09 08:22 PM
07/07/09 08:22 PM
John_Kunkel
Rio Linda, CA
The original design taper roller bearing is superior to the Green ball bearing, the only logical reason to change to the Green bearing is when doing a disc brake swap.
[Re: John_Kunkel]
#368173
07/07/09 10:40 PM
07/07/09 10:40 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
I'm currently restoring the rear end in my 57 Plymouth (same rear as your 61). John Krunkel is right, the stock bearings are great, if bad or rusty just replace them with oem replacements. Tappered axle rears get a bad rap for having the drums you have to use a puller to remove, it's a pain but with the correct tools is a breeze. When I did mine the hardest part for me was the learning curve in pulling the brake drums off of the tapered axle rear, they are usually tight and stubborn to come off. I learned the hard way that you need to use the correct puller to remove them, if you do it's a piece of cake. Use the Les Fairbanks puller....PERIOD! You have to pull evenly on all 5 lugs or the drum will bind, I used a 3 leg/lug puller the first time, the drum came off but it required a sledge hammer and was VERY difficult, not good on the drums or axles. Fairbanks Puller
