Re: Do-it- yourself Front End Alignment Help Needed.
[Re: mymcodebee]
#367883
07/06/09 10:51 AM
07/06/09 10:51 AM
RapidRobert
If I absolutely had to I'd put it on a level driveway,steering wheel straight, crank up tbars for ride height,adj tie rod sleeves till the tire treads are parallel then move the front of each tire in a 1/32" then put a carpenters level vertical on each tire & get it level(0 camber)
[Re: mymcodebee]
#367887
07/06/09 11:44 AM
07/06/09 11:44 AM
Posts: 21,840 Kirkland, Washington
Pacnorthcuda
Camber is the easiest to get in the ballpark. 1) Park on level concrete, wheels straight of course. 2) Place a level against the top (12:00 O clock) position of the rim and the bottom (6:00) 3) Adjust Camber till true vertical (thats 0 degrees) done.
You will find the hard part is adjusting the camber bolts while the suspension is loaded...it will want to 'fall' when you loosen, so it turns into a trial and error procedure whereby you unload the suspension, make an adjustment, lower the car, roll the car (at least 6 feet or so), and check. MUCH easier if you mark your bolt washers (the offset adj washers) with a sharpie as you go, that way you know where you've been and what direction you need to go.
I forgot----best to START the adjustment by adjusting both adjusters (on each corner) for max caster, THEN adjust for 0 camber (you will remove some caster in the process).
[Re: Pacnorthcuda]
#367888
07/06/09 12:49 PM
07/06/09 12:49 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
Important step there. Bouncing does not sufficiently allow the tires to spread out to where they were.
The caster will be pretty much out of the question without a gauge. At home this is not easy.
Like they said, toe and caster is not much of an issue. I do toe setting at home all the time. Problem with camber adjustments at home is it disturbs the caster.
For what it's worth. This job is 10 times easier on a rack, with plates and reference to the rear wheels. You can see all 3 (actually more) adjustments for EVERY move you make. At home you have to recheck each one over and over after each move. My vote is do it on a rack.
[Re: 72challorange]
#367890
07/07/09 09:36 AM
07/07/09 09:36 AM
Posts: 2,968 Far Northeast.
mymcodebee
Far Northeast.
I just it back off the rack for $75 from a local garage. They did a nice job. Not really worth the risk when you factor in a 10 hour drive to Carlisle.. I will have enough other issues to worry about I'm sure. Thanks for the input everyone. See you at Carlisle. Reid
[Re: mymcodebee]
#367891
07/08/09 06:58 PM
07/08/09 06:58 PM
Posts: 824 NH
72challorange
He's Game
He's Game
NH
See you there! Driving down in the AM. Tom
