Re: procomp distributor and coil wiring
[Re: CIB]
#367666
07/05/09 11:14 PM
07/05/09 11:14 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
first what distributor do you have? Pro comp sells a several
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: CIB]
#367670
07/06/09 06:00 PM
07/06/09 06:00 PM
Posts: 7,759 So Cal
HealthServices
So Cal
I don't think it is a big concern unless you drive in a dusty or wet enviroment. MSD even sells a vented dist cap for some applications.
Allen
[Re: HealthServices]
#367671
07/06/09 06:59 PM
07/06/09 06:59 PM
Posts: 565 IA
landon1
IA
i was thinking....maybe you have the same set-up as me, but you have one pigtail coming off of the positive wire and one off the negative wire. could this be for a race car situation where they assume you'll run those wires to a toggle or rocker switch in the car? that's how mine is set-up(toggle + push-button), but my wires run off the coil, not off the distributor wires (same thing)
'71 Satellite Sebring 440
[Re: CIB]
#2121547
07/30/16 09:48 PM
07/30/16 09:48 PM
Posts: 201 Martin TN
ridin98ci
Martin TN
I could really use a laymans wiring diagram for this set up......PLEASE
LOUD AND PROUD!!!
