I think my MSD is dying. What do you think? #367616
07/05/09 09:44 PM
07/05/09 09:44 PM
Huron, South Dakota, United St...
dustyhof Offline OP
dustyhof  Offline OP
Took the Dart out this weekend to do some T&T on Saturday and race today, but had some bad luck. I think it kinda started this winter when I was welding holes shut in the firewal and the kick panel started on fire where the MSD 6AL was mounted. The edge of it got hot enough to melt the rev limiter chip. I thought it was toast for sure, but when I got the car back together, it fired right up and seemed to run fine. The car seemed to work perfectly on Sat. during T&T, running a new best, as well as the first time trial today. The second run the car seemed almost like it was loading up, even though it was not rich. During the run it would'nt hardly climb past 5000 RPM and the tach was bouncing all over the place. It would spit and sputter around 5K for a bit, then it would climb to 7200. I'd hit the next gear, and it would do the same thing all over again. Every run got worse from there. It will idle fine, but the tach would bounce around every once in a while. I ran an 11.34 yesterday, and the last run today was a 12.04! This problem was just one of the many things that went wrong this weekend. The CD player in my trailer got wet towing in the rain, and fried. The cabinet door right next to the windshield on the right side of the trailer came open on the way home and busted the windshield out of the Dart! What else can I break this weekend!
Re: I think my MSD is dying. What do you think? [Re: dustyhof] #367617
07/05/09 10:16 PM
07/05/09 10:16 PM
dustyhof Offline OP
dustyhof  Offline OP
Forgot to mention that I replaced the pill, but not the box. Sorry.
Re: I think my MSD is dying. What do you think? [Re: dustyhof] #367618
07/05/09 10:29 PM
07/05/09 10:29 PM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
Sorry bout the bad luck. Sounds like it is probable that the MSD is bad, but after what I eperienced today, just make sure that a jet did not fall out of the metering block
Re: I think my MSD is dying. What do you think? [Re: wheelsup68dart] #367619
07/05/09 10:40 PM
07/05/09 10:40 PM
dustyhof Offline OP
dustyhof  Offline OP
Ok. Thanks. I never thought of that. I'll look.
Re: I think my MSD is dying. What do you think? [Re: dustyhof] #367620
07/05/09 11:40 PM
07/05/09 11:40 PM
Check all of the electrical connections including the reluctor for corrsion and fit
Re: I think my MSD is dying. What do you think? [Re: Cab_Burge] #367621
07/06/09 12:04 AM
07/06/09 12:04 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Double-check the reluctor gap..
Depending upon the brand of distributor, if this gap is too wide then the reluctor doesn't close fully and the MSD box may not fire reliably. Also be sure to have a solid 12V connections and kleen ground.
Just my $0.025..
