Drum brake problem #367609
07/05/09 09:39 PM
07/05/09 09:39 PM
dark side of the moon
Dougsmopars Offline OP
Car has much less pressure to front breaks then rears. When bleeding rears shoot fluid across the car fronts shoot fluid about 4 inches. Previous owner had 2 line locks installed, one on each line from master. I have no idea why. I'm wondering if he swaped the lines from master to proportioning valve??? Which port does front brake feed line go to and which port does rear line go to? I want to check if he has them backwards. I'm getting less pressure to front breaks.
Re: Drum brake problem [Re: Dougsmopars] #367610
07/05/09 11:31 PM
07/05/09 11:31 PM
The M/C port next to the firewall is for the front brakes if that is what you are asking (not familiar w line locks)
Re: Drum brake problem [Re: RapidRobert] #367611
07/06/09 06:23 AM
07/06/09 06:23 AM
Looking to see which port on proportioning valve is front feed from master and which is rear feed from master
