ultradyne cam needs spec #367586
07/05/09 09:04 PM
07/05/09 09:04 PM
Anonymous OP
Anonymous OP
can anyone tell me what the specs are on this cam lost the cam card
Ultradyne #316r8 big block
Re: ultradyne cam needs spec #367587
07/05/09 09:25 PM
07/05/09 09:25 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Where did you get the #316r8 from??
The only Specs I have for his BB grinds all start with NF. As in NF 70,62,61,ETC. mike
Re: ultradyne cam needs spec [Re: Sport440] #367588
07/05/09 09:30 PM
07/05/09 09:30 PM
gregsdart Offline
gregsdart  Offline
Searching bullet cams, they have an Ultrdyne master list, but those numbers don't jive.
Re: ultradyne cam needs spec [Re: Sport440] #367589
07/05/09 09:31 PM
07/05/09 09:31 PM
Anonymous OP
Anonymous OP
the number is on a old invoice ftom Muscle motors
it also says ultradyne 682 cam
Re: ultradyne cam needs spec #367590
07/05/09 09:35 PM
07/05/09 09:35 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
R11 roller lobe 316@.020 283@.050 202@.200 .682 with 1.5 rocker 108 lsa.
Re: ultradyne cam needs spec [Re: goldmember] #367591
07/05/09 10:08 PM
07/05/09 10:08 PM
Anonymous OP
Anonymous OP
Thanks Goldmember
I found a comp cam number rx316r-8
that is close to the numbers you have
I have 1.7 rockers
316 321
283 288@50
660 663
108 lsa
4800 to 7200 rpm
I am trying to match up a convertor for my new car
84 Dodge Daytona top sportsman
Re: ultradyne cam needs spec #367592
07/06/09 03:04 AM
07/06/09 03:04 AM
Utah
topbrent Offline
topbrent  Offline
Utah
Call Bullet Racing Cams at (662)893-5670
Ask for Tim.
