Re: Backfiring thru exhaust..?
[Re: MoparforLife]
#366750
07/04/09 07:08 PM
07/04/09 07:08 PM
fouled plug or loose header bolts.
[Re: MoparforLife]
#366753
07/04/09 07:49 PM
07/04/09 07:49 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
not to pick nits, but a backfire is out the carb, not the exhaust. What you have is called a MISfire. Which means it's not burning in the combustion chamber but in the exhaust.
[Re: MoparforLife]
#366755
07/04/09 08:48 PM
07/04/09 08:48 PM
Supercuda
About to go away
About to go away
up yours
No, everyone doesn't "know what it means" hence the comment. When words is all you have use the right ones otherwise you get the wrong answers. Unless his exhaust is suck birds out of the air and small kids off the sidewalks it's not "backfiring" out the exhaust, it's misfiring.
[Re: Supercuda]
#366757
07/05/09 08:11 AM
07/05/09 08:11 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
I really don't think that you do! But I think most do realize what the term backfire refers to:
What is a Backfire?
There are typically two kinds of engine backfires, one is generated from the intake manifold of the engine, and the second is expelled from the exhaust pipe at the rear of the car. A backfire is an explosion of sorts in the intake manifold or the exhaust system. A backfire occurs when there is an imbalance in the air to fuel ratio required for your vehicle to operate properly. If the fuel mixture is too lean (not enough fuel) you may have a backfire in the intake, or too rich (too much fuel) you may get a backfire out of the exhaust system. Most backfires are easily repaired by correcting the imbalance and providing a greater or lesser percentage of fuel to the mixture. Also read: http://en.wikipedia.org/wiki/Back-fire
[Re: Supercuda]
#366759
07/05/09 08:42 AM
07/05/09 08:42 AM
MoparforLife
Upper Midwest
And the term misfire refers to and engine 'misfiring' not nessessarly popping through the exhaust although due to the misfire an accumulation of fuel can occur in the exhust system and a explosion that you refer to as as a backfire can occur: Misfire is a common driveability problem that may or may not be easy to diagnose, depending on the cause. A misfiring cylinder in a four-cylinder engine is, pardon the pun, hard to miss. The loss of 25% of the engine's power output is the equivalent of a horse trying to run on three legs. The engine may shake so badly at idle that it causes vibrations that can be felt in the steering wheel and throughout the vehicle. The engine also may be hard to start and may even stall at idle, depending on the accessory load (air conditioning, headlights and electric rear defroster, for example).
When misfire occurs, performance suffers along with fuel economy, emissions and idle quality. And, when a misfiring vehicle is subjected to an emissions test, it will usually fail because of the unusually high levels of hydrocarbons (HC) in the exhaust.
What causes a cylinder to misfire? Basically, it's one of three things: loss of spark; the air/fuel mixture is too far out of balance to ignite; or loss of compression. Loss of spark includes anything that prevents coil voltage from jumping the electrode gap at the end of the spark plug. Causes include worn, fouled or damaged spark plugs, bad spark plug wires or even a cracked distributor cap. A weak coil or excessive rotor gas inside a distributor would affect all cylinders, not just a single cylinder.
"Lean misfire" can occur when the air/fuel mixture is too lean (not enough gasoline in the mixture) to burn. This can be caused by a dirty, clogged or inoperative fuel injector; air leaks; or low fuel pressure because of a weak pump, restricted filter or leaky pressure regulator. Low fuel pressure would affect all cylinders rather than an individual cylinder, as would most air leaks. A leaky EGR valve can also have the same effect as an air leak.
Loss of compression means the cylinder loses most of its air/fuel mixture before it can be ignited. The most likely causes here are a leaky (burned) exhaust valve or a blown head gasket. If two adjacent cylinders are misfiring, it's likely the head gasket between them has failed. Also, if an engine is overheating or losing coolant, it's likely the head gasket is the culprit.
Intermittent misfires are the worst kind to diagnose because the misfire comes and goes depending on engine load or operating conditions. They seem to occur for no apparent reason. The engine may only misfire and run rough when cold but then smooth out as it warms up. Or, it may start and idle fine but then misfire or hesitate when it comes under load. Also, it may run fine most of the time but suddenly misfire or cut out for no apparent reason. Intermittent misfires can be a real challenge to diagnose, so let's start with a steady misfire in one cylinder before moving on to intermittent misfires.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
