Backfiring thru exhaust..? #366748
07/04/09 06:40 PM
07/04/09 06:40 PM
Myrtle Beach, SC formerly the ...
340wedge Offline OP
340wedge  Offline OP
I took the Duster out today and sometimes under acceleration it backfires through the exhaust. Could this be the choke or something else? ..
1971 Sassy Grass Green Duster 340
2006 Charger Daytona GoMango
Re: Backfiring thru exhaust..? [Re: 340wedge] #366749
07/04/09 07:04 PM
07/04/09 07:04 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
If you have been working on the engine make sure that 5 & 7 plug wires are on the correct plugs. They are right next to each other in the cap and on the engine and they fire one after teh other and at so close together that at times at idle the miss is hardly noticable, but put a little load on the engine and it does just what you discribe.
Re: Backfiring thru exhaust..? [Re: MoparforLife] #366750
07/04/09 07:08 PM
07/04/09 07:08 PM
fouled plug or loose header bolts.
Re: Backfiring thru exhaust..? #366751
07/04/09 07:46 PM
07/04/09 07:46 PM
Upper Midwest
Upper Midwest
Or vac leak.
Re: Backfiring thru exhaust..? [Re: 340wedge] #366752
07/04/09 07:49 PM
07/04/09 07:49 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Check for burned sparkplug cables.
Re: Backfiring thru exhaust..? [Re: MoparforLife] #366753
07/04/09 07:49 PM
07/04/09 07:49 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
not to pick nits, but a backfire is out the carb, not the exhaust. What you have is called a MISfire. Which means it's not burning in the combustion chamber but in the exhaust.
Don't be the exception.
Re: Backfiring thru exhaust..? [Re: Supercuda] #366754
07/04/09 08:05 PM
07/04/09 08:05 PM
Upper Midwest
Upper Midwest
The term was used as a generality and every one knows what was meant and the term 'backfire' commonly used. when a engine misfires it can accumulate fuel into the exhuast which can as you say cause your so called backfire.
Re: Backfiring thru exhaust..? [Re: MoparforLife] #366755
07/04/09 08:48 PM
07/04/09 08:48 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
No, everyone doesn't "know what it means" hence the comment.
When words is all you have use the right ones otherwise you get the wrong answers.
Unless his exhaust is suck birds out of the air and small kids off the sidewalks it's not "backfiring" out the exhaust, it's misfiring.
Re: Backfiring thru exhaust..? [Re: 340wedge] #366756
07/04/09 10:15 PM
07/04/09 10:15 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Valve float or bad spring?
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Backfiring thru exhaust..? [Re: Supercuda] #366757
07/05/09 08:11 AM
07/05/09 08:11 AM
Upper Midwest
Upper Midwest
I really don't think that you do!
But I think most do realize what the term backfire refers to:
What is a Backfire?
There are typically two kinds of engine backfires, one is generated from the intake manifold of the engine, and the second is expelled from the exhaust pipe at the rear of the car. A backfire is an explosion of sorts in the intake manifold or the exhaust system. A backfire occurs when there is an imbalance in the air to fuel ratio required for your vehicle to operate properly. If the fuel mixture is too lean (not enough fuel) you may have a backfire in the intake, or too rich (too much fuel) you may get a backfire out of the exhaust system. Most backfires are easily repaired by correcting the imbalance and providing a greater or lesser percentage of fuel to the mixture.
Also read: http://en.wikipedia.org/wiki/Back-fire
Re: Backfiring thru exhaust..? [Re: MoparforLife] #366758
07/05/09 08:18 AM
07/05/09 08:18 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: Backfiring thru exhaust..? [Re: Supercuda] #366759
07/05/09 08:42 AM
07/05/09 08:42 AM
Upper Midwest
Upper Midwest
And the term misfire refers to and engine 'misfiring' not nessessarly popping through the exhaust although due to the misfire an accumulation of fuel can occur in the exhust system and a explosion that you refer to as as a backfire can occur:
Misfire is a common driveability problem that may or may not be easy to diagnose, depending on the cause. A misfiring cylinder in a four-cylinder engine is, pardon the pun, hard to miss. The loss of 25% of the engine's power
output is the equivalent of a horse trying to run on three legs. The engine may shake so badly at idle that it causes vibrations that can be felt in the steering wheel and throughout the vehicle. The engine also may be hard to start and may even stall at idle, depending on the accessory load (air conditioning, headlights and electric rear defroster, for example).
When misfire occurs, performance suffers along with fuel economy, emissions and idle quality. And, when a misfiring vehicle is subjected to an emissions test, it will usually fail because of the unusually high levels of hydrocarbons (HC) in the exhaust.
What causes a cylinder to misfire? Basically, it's one of three things: loss of spark; the air/fuel mixture is too far out of balance to ignite; or loss of compression. Loss of spark includes anything that prevents coil voltage from jumping the electrode gap at the end of the spark plug. Causes include worn, fouled or damaged spark plugs, bad spark plug wires or even a cracked distributor cap. A weak coil or excessive rotor gas inside a distributor would affect all cylinders, not just a single cylinder.
"Lean misfire" can occur when the air/fuel mixture is too lean (not enough gasoline in the mixture) to burn. This can be caused by a dirty, clogged or inoperative fuel injector; air leaks; or low fuel pressure because of a weak pump, restricted filter or leaky pressure regulator. Low fuel pressure would affect all cylinders rather than an individual cylinder, as would most air leaks. A leaky EGR valve can also have the same effect as an air leak.
Loss of compression means the cylinder loses most of its air/fuel mixture before it can be ignited. The most likely causes here are a leaky (burned) exhaust valve
or a blown head gasket. If two adjacent cylinders are misfiring, it's likely the head gasket between them has failed. Also, if an engine is overheating or losing coolant, it's likely the head gasket is the culprit.
Intermittent misfires are the worst kind to diagnose because the misfire comes and goes depending on engine load or operating conditions. They seem to occur for no apparent reason. The engine may only misfire and run rough when cold but then smooth out as it warms up. Or, it may start and idle fine but then misfire or hesitate when it comes under load. Also, it may run fine most of the time but suddenly misfire or cut out for no apparent reason. Intermittent misfires can be a real challenge to diagnose, so let's start with a steady misfire in one cylinder before moving on to intermittent misfires.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Backfiring thru exhaust..? [Re: MoparforLife] #366760
07/05/09 08:56 AM
07/05/09 08:56 AM
Upper Midwest
Upper Midwest
By the way you can create your own misfired backfire but taking taking the car up in speed in a lower gear and letting the car coast with engine braking the momentum and turning the ignition off and then just before you stop turning the ignition back on. The resulting explosion can destroy the exhuast system or other parts as well.
