426 HEMI and Fuel Injection #366562
07/04/09 03:26 PM
07/04/09 03:26 PM
Dalton, MA
Slipknot440 Offline OP
Dalton, MA
looking at an EFI unit for my hemi and would like some opinions or experiences with EFI on an old school engine.
Re: 426 HEMI and Fuel Injection [Re: Slipknot440] #366563
07/04/09 03:38 PM
07/04/09 03:38 PM
Canada
CrAzYMoPaRGuY Offline
Canada
What configuration intake are you looking at using?
CrAzYMoPaRGuY
Re: 426 HEMI and Fuel Injection [Re: CrAzYMoPaRGuY] #366564
07/04/09 03:44 PM
07/04/09 03:44 PM
Dalton, MA
Dalton, MA
it's an INDY set-up with the fuel rails going directly into the manifold. I don't know much about them on old cars, but seems like it would be better than my edelbrock 800 and m1 intake
Re: 426 HEMI and Fuel Injection [Re: Slipknot440] #366565
07/04/09 04:11 PM
07/04/09 04:11 PM
Canada
Canada
If you have the intake I'm thinking the biggest decision is going to be which ECU.....?
When my intake was done it had injectors too small for the application installed, and the lines weren't done in a way in which I could leave on the car, the throttle bracket was made twice, once by the EFI guy and once by the engine builder, neither bracket would even work. There was no return provision for the fuel system whatsoever and somehow it was claimed it ran on a dyno. Who knows...
What I am saying is.... if I did it again I would do the intake conversion myself. No doubt about it! Nothing worse than paying to have something made, then not liking some things, some things don't work etc so you HAVE to remake things you've already (over)paid for....
CrAzYMoPaRGuY
Re: 426 HEMI and Fuel Injection [Re: Slipknot440] #366566
07/04/09 04:16 PM
07/04/09 04:16 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
i think it would look crazy hacked on stock looking muscle car, plus you would have to run all new feul system like race car all braided lines/an fittings, custum cell with efi pump, and return lines, then figure out were the mile of wires/computer are going to go? would be cool on old street rod. you can buy dual four intake/carbs/cleaner pretty cheap now id go that route,nothing sounds better than hemi with both carbs wide open
MOPAR OR NO CAR
Re: 426 HEMI and Fuel Injection [Re: CrAzYMoPaRGuY] #366567
07/04/09 04:16 PM
07/04/09 04:16 PM
Canada
Canada
This is what I paid money for and got..
CrAzYMoPaRGuY
Re: 426 HEMI and Fuel Injection [Re: CrAzYMoPaRGuY] #366568
07/04/09 04:16 PM
07/04/09 04:16 PM
Dalton, MA
Dalton, MA
it's moparts member that has one for sale with the ecu, rails, manifold, throttle body etc. says its complete. hhow has the performance been with it as opposed to the carb?
Re: 426 HEMI and Fuel Injection [Re: CrAzYMoPaRGuY] #366569
07/04/09 04:17 PM
07/04/09 04:17 PM
Canada
Canada
This is what I did myself, WITH a proper return system.... and correct injectors.....
CrAzYMoPaRGuY
Re: 426 HEMI and Fuel Injection [Re: Slipknot440] #366570
07/04/09 04:21 PM
07/04/09 04:21 PM
Canada
Canada
Mine isn't running yet. I'm sure tomatoes will be thrown at me soon if it doesn't get running.
Mine is an individual runner intake, which is different than most intakes as far as characteristics go. I think the absolute ultimate hp numbers can usually be gotten with a carb if I'm not mistaken, but when the horsepower and torque are measured from idle to top rpm there wouldn't be much of a comparison in most cases, the EFI provides a well tuned engine for A/F ratios compared to carbs. Depends on the system and who tunes it I guess...
CrAzYMoPaRGuY
Re: 426 HEMI and Fuel Injection [Re: hemigod426] #366571
07/04/09 04:23 PM
07/04/09 04:23 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Looks pretty hacked up to me.
Re: 426 HEMI and Fuel Injection [Re: moparpollack] #366572
07/04/09 06:10 PM
07/04/09 06:10 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
My hemi is fuel injected.
If you don't like quick starting and smooth idling than stick with a carb.
Tim at FHO has a 2-4 fi setup that once the air cleaner is on you would never know it was injected.
The biggest thing is the system that you run.
I have a Fast xfi but if you get into buying a older antiquated system the tuning headaches wont be worth it.
Fuel injection is awesome.
Re: 426 HEMI and Fuel Injection [Re: The Shadow] #366573
07/04/09 10:42 PM
07/04/09 10:42 PM
Dalton, MA
Dalton, MA
would it add any more power or just make the power available more readily available/efficient. fuel mileage?
Re: 426 HEMI and Fuel Injection [Re: Slipknot440] #366574
07/04/09 11:09 PM
07/04/09 11:09 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
More power depends on how good you are at tuning a carb. I will tinker with a carb to get everything I can out of it, but most systems, efi vs carb, are within a few ponies. The advantages of the efi are super easy starting and idling, along with far better milage. There are systems out there that are not a lot of hassle. The new EZ-EFI from FAST is one that is self learning, and does not require a laptop.
I have been running EFI on Hemis for some time now, and like anything else, a well designed system will keep you away from many of the issues that can plague an engine converted to EFI with the wrong componants.
I run the older classic FAST system on my hemi, and would not trade it for two carbs. The system you saw for sale is an Accel DFI system, and they can be difficult to work with. Its a good deal price wise, but not easy to set-up or tune.
My car right out of winter storage for a Febuary in Buffalo car show....
[image][/image]
Race Tune with full mufflers
[image][/image]
Mopar Nats, street tune-up
[image][/image]
EZ-EFI by FAST
http://www.youtube.com/watch?v=5IX1F4V1Yi0
Re: 426 HEMI and Fuel Injection [Re: hemigod426] #366575
07/05/09 04:32 AM
07/05/09 04:32 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
OEM efi cars didn't run braided lines or an fittings, so I don't see why you bring that up. For EFI pumps there are several options that use a stock gas tank, fuel cell is not needed. If adding one return line is like pulling teeth to you, you probably don't know how to tune a carb anyway. Yes you will have to see the injectors and fuel rails, but if you run your wiring carefully and run an oval 6-pack style air cleaner you can hide most of the EFI hardware/fuel system, even with a multiport setup. And if laid out with care and combined with your stock wiring harness, the extra wiring for the efi system need not be clearly visible. Likely won't make it 100% invisible but you can hide a lot of it.
Re: 426 HEMI and Fuel Injection [Re: Slipknot440] #366576
07/05/09 12:12 PM
07/05/09 12:12 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
You should checkout the photos page on my web site.
www.fastmanefi.com
I've done a "ton" of EFI Hemis. Probably more than anyone else. Personally I like the new dual TB manifold from Stage-V. Let me know if I can assist in any way.
Re: 426 HEMI and Fuel Injection [Re: Slipknot440] #366577
07/05/09 12:30 PM
07/05/09 12:30 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Be aware that some systems don't work well with too radical of a cam. So If you are going in this direction, ask to see if it will run well with your cam.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: 426 HEMI and Fuel Injection [Re: DaytonaTurbo] #366578
07/05/09 01:02 PM
07/05/09 01:02 PM
hemigod426 Offline
hemigod426  Offline
was just trying to prepare the guy for the radical changes he will have to do,he dosent know thanks why he was asking.so you have the capability to make your own stainless or plastic quick disconnect efi lines? how can you ass-ume i dont know carbs when all my cars are dual quad hemi or 440 six pack all rebuilt by me. lets see pics of your super clean efi install on anything.....nice winter car in sig
MOPAR OR NO CAR
Re: 426 HEMI and Fuel Injection [Re: hemigod426] #366579
07/05/09 01:25 PM
07/05/09 01:25 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
You appear to have absolutely have no idea what your talking about
Why would you need quick disconnect efi lines? The only major changes to the fuel system is a return line,high pressure pump, and regulator
Just look at some of Rich's installs if you want any idea of how neat efi systems can be.
Don't keep your head in the sand when it comes to F.I. The technology is incredible.
Re: 426 HEMI and Fuel Injection [Re: hemigod426] #366580
07/05/09 01:33 PM
07/05/09 01:33 PM
buffalo, new york
0
00snake530 Offline
00snake530  Offline
buffalo, new york
70 Challenger r/t 4 speed
00 Viper gts
67 satellite pro street
03 Ferrari 360 spider
50 chevy fleetline deluxe
15 Escalade (daily)
Re: 426 HEMI and Fuel Injection [Re: The Shadow] #366581
07/05/09 01:36 PM
07/05/09 01:36 PM
hemigod426 Offline
hemigod426  Offline
yes ive looked at them for years, now the tech, and manifolds i want are finally here have talked to tim-b about the 2x4 efi on stage-v street hemi intake allready, wont be long before i convert a carbed hemi over
MOPAR OR NO CAR
