Changed to Manual brakes from power brakes #366526
07/04/09 03:06 PM
07/04/09 03:06 PM
Illinois
saukvillage Offline OP
Illinois
I replaced the push rod for a stock manual brake rod, stock backing plate,I retained the stock power brake proportioning valve and stock master cylinder. I bled the brakes front and rear, O.K. After said and done My front two calipers locked to the rotors and will not release unless I open up a bleeder screw. What is the problem now ? I have a line lock connected, working fine. 73 challenger, Thanks to all for your help.
Re: Changed to Manual brakes from power brakes [Re: saukvillage] #366527
07/04/09 03:38 PM
07/04/09 03:38 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Push rod too long and not releasing pressure could be one problem
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Changed to Manual brakes from power brakes [Re: HealthServices] #366528
07/04/09 06:07 PM
07/04/09 06:07 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
You need to have a slight gap between the MC piston and push rod when the MC is bolted in. I shoot for 1/8" gap.
Re: Changed to Manual brakes from power brakes [Re: Lefty] #366529
07/04/09 07:09 PM
07/04/09 07:09 PM
Ferlin Offline
Ferlin  Offline
Hey Howard, Let me know if you need help! Ferlin
