problems with 426 Hemi blocks that have been windowed ? #366280
07/04/09 12:46 PM
07/04/09 12:46 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Well,first off..Happy 4th to all!
Now..Chryslers at Carlisle starts this next week and every year there are a few Hemi blocks that are for sale, some that were windowed and repaired and some that are at max bore and need to be sleaved. I have seen these priced cheep but usually don't sell so.....
I would like to know if anyone that knows these Hemi Blocks would consider one for a Hot street machine.....that has any of the above problems or would you just buy a new block and start with that?
Thanks!
Re: problems with 426 Hemi blocks that have been windowed ? [Re: GLR] #366281
07/04/09 03:25 PM
07/04/09 03:25 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
New blocks have been at $2500 which makes messing with old, broken parts not worthwhile. I would use a sleeved block before one that has been broken though.
Sheldon
Re: problems with 426 Hemi blocks that have been windowed ? [Re: RUNCHARGER] #366282
07/04/09 04:25 PM
07/04/09 04:25 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Yes, I have seen the new blocks for that also but the one's that I have seen at Carlisle are $700-to $1200.00...but like I say the have been repaired or need sleves
I also have been thinking about building a 6.1 new style Hemi into a 426 but there doesn't seam to be any used engines out there yet.
Re: problems with 426 Hemi blocks that have been windowed ? [Re: GLR] #366283
07/04/09 09:21 PM
07/04/09 09:21 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
If I found a block that was the right build date for my '67 GTX that needed to be sleeved, I wouldn't hesitate at all about buying it. If I was just building a Hemi engine, the current block is the way to go. As to repairs, it would have to be something cosmetic like a window in the pan rail for me to consider it. Some of these blocks with cracks in the main bores or the lifter galley, I don't care if God himself did the repair, I wouldn't touch them.
Re: problems with 426 Hemi blocks that have been windowed ? [Re: RUNCHARGER] #366284
07/04/09 09:36 PM
07/04/09 09:36 PM
RUNCHARGER Offline
RUNCHARGER  Offline
My car is an original Hemi car and I am running a new block in it. I can't believe that when I was trying to sell the car, people were disappointed it didn't have a wasted 66 block in it. I would much sooner have an intact, standard bore block than some wadded up ex-racer fare. Of course I actually drive my car so integrity of the block is a big deal to me.
Sheldon
Re: problems with 426 Hemi blocks that have been windowed ? [Re: RUNCHARGER] #366285
07/05/09 12:53 PM
07/05/09 12:53 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
Nothing wrong with sleeves. As long as you have a good 1/2 to 1 inch of cylinder wall at bottom of skirt. But you want to consider it runs a couple of hundred bucks per sleeve to have them installed. So weigh it out. Nice block that needs one or two sleeves might not be a bad deal. If it needs all eight then it might be expensive. I prefer an aged block that has been stress releived over a new block. Kind of depends on how wild your going to get with the motor.
Re: problems with 426 Hemi blocks that have been windowed ? [Re: Dougsmopars] #366286
07/05/09 03:14 PM
07/05/09 03:14 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
I'd stay away from blocks that had the water jackets filled, as I'm not sure if they would cool very well in a street car.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: problems with 426 Hemi blocks that have been windowed ? [Re: HealthServices] #366287
07/05/09 04:38 PM
07/05/09 04:38 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
O.K.
Thank you guys for all the input on this.
Re: problems with 426 Hemi blocks that have been windowed ? [Re: GLR] #366288
07/05/09 05:24 PM
07/05/09 05:24 PM
Culberson, NC
Chargerbee Offline
Chargerbee  Offline
Culberson, NC
You will be spending so much on building your Hemi that it will be self defeating and foolish to skimp on something as crucial as the block.
I made that mistake and I have a $1000 boat anchor.
If the block was not properly heated when the cast iron welding was performed, the block will come apart.
I've also seen plenty of blocks that should have never been sleeved end up sleeved.
Before the Atlanta Connection closed, I ended up buying the last block Lawrence Roundtree had and that's what I should have done in the first place.
