edlebrock intake sp2p318 #366136
07/04/09 09:23 AM
07/04/09 09:23 AM
akron ohio
moparmanjr Offline OP
akron ohio
i have a edelbrock sp2p 318
intake i was wondering if they made
more than one kind of these intakes
mine has an offset thermostate housing on
it not the standard mopar let me know if
anyone has a part # thanks iwanted to know
what years this fits
Re: edlebrock intake sp2p318 [Re: moparmanjr] #366137
07/04/09 10:23 AM
07/04/09 10:23 AM
scratchnfotraction Offline
it will fit 67 through 91 318 heads with the small ports
IMO,not that good of an intake..but is a gas mizer for the 318s
Re: edlebrock intake sp2p318 [Re: scratchnfotraction] #366138
07/04/09 12:14 PM
07/04/09 12:14 PM
hooziewhatsit Online content
hooziewhatsit  Online Content
I have an SP2P on my 318. I thought the thermostat housing was in the same place as the stock 2bbl intake I took off
The intake seems to work fine for me. It's a work truck, and rarely goes over 3k rpms
As for mileage... It got a whole 10.7mpg this last tank
Re: edlebrock intake sp2p318 [Re: hooziewhatsit] #366139
07/04/09 01:18 PM
07/04/09 01:18 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
Best for the street, idle to 4800 rpm intake is the 318 Streetmaster edelbrock single splane low rise.
enter the octagon ...
My intake has a 2" spacer for the full pull to 5,200 rpm(shift point).
areoheads 1.88/1.60 318 quench heads shaved .060
factory adjustable rockers
streetmaster 318 single plane
600 holley vac sec yello spring long
340/290 hp cam .430/.444" 114
headman headers 15/8 /3" to dual packs into turbos
should make 375-400hp, but only 240 rwhp.
Re: edlebrock intake sp2p318 [Re: mark7171] #366140
07/04/09 05:12 PM
07/04/09 05:12 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
So let me get this straight, you took a 290 hp 340 gave it worse heads, worse intake and a smaller bore and think it is makeing 100 more hp?
Re: edlebrock intake sp2p318 [Re: HotRodDave] #366141
07/04/09 05:22 PM
07/04/09 05:22 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
SP2P is a great low RPM intake. For MPG's. They used to say "stock manifolds, cam, etc."
It also came in a 2bbl version. I had a spreadbore model, there might have been a square for model. Never ran it. I sold it to QBird here. He was going to build a '73 or 74 Charger with a 318 for a MPG type build like Dave did.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: edlebrock intake sp2p318 [Re: HotRodDave] #366142
07/04/09 07:36 PM
07/04/09 07:36 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
with a samller engine the cam acts more aggressive. The cut 302? heads are the same valve size, same potential performance.
Headers are added, and a crank scrapper...so 275-400 hp.
with 3.23 gears, mpg wise its around 14-16.
Re: edlebrock intake sp2p318 [Re: mark7171] #366143
07/04/09 07:41 PM
07/04/09 07:41 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The 290 hp 340 had biggeer ports and 2.02 valves not the 1.88 you have in your heads. Also the single plane you are useing has VERY small diameter runners that are very long and therefore it will be a low rpm manifold not high rpm like a typical single plane. I think the wheel HP you are makeing is right in line with what you have. Headers are the only improvement you have over a 340 everything else you mention is costing you hp when compared to a 340
