E-body remote mirror question
#365954
07/04/09 12:10 AM
07/04/09 12:10 AM
Posts: 1,912 Anchorage, Alaska
Iceman01
Challenged
Challenged
Anchorage, Alaska
Could someone please measure their 1970 Challenger inside drivers door panel for the correct mounting location of the remote side-view mirror toggle lever?
I'm installing my restored door panels and discovered there is no hole in the driver side to mount the remote mirror toggle lever. I bought the car disassembled and with its original door panels, so apparently the car came new with a standard mirror and the previous owner bought this remote model to install. Now I have to cut a hole and want to be sure I do it in the right place.
There is a stamped, dotted circle on the backside in the area where the hole should be, but the same marking also exists on the passenger door panel (where no remote mirror was available), so I'm not certain it is the correct location.
Until total honesty is on the table, we're not even talking about reality...
Re: E-body remote mirror question
[Re: Alaskan_TA]
#365957
07/04/09 03:33 AM
07/04/09 03:33 AM
Iceman01
Challenged
Challenged
Anchorage, Alaska
Thanks Barry, that's the mark I was referring to on the back of mine. Weird that it would be on both sides though. Anyhow, I'll verify cable length/operation before cutting.
[Re: Iceman01]
#365959
07/07/09 01:30 AM
07/07/09 01:30 AM
Iceman01
Challenged
Challenged
Anchorage, Alaska
Okay, so I go out to mock it all up before cutting and discover that the cables as currently routed are not long enough to reach the inner door panel. They are currently running from the mirror down through a hole in a stock-looking bracket bolted to the inside front vertical edge of the actual door. The bracket is pointing downward with the hole located approximately mid-door. With the cable routed through it, there is not enough slack to route it back up to the correct location on the inside door panel. It does look like the bracket could be rotated 180 degrees to point upwards instead. That might provide the needed slack. Can anyone confirm the correct cable routing and bracket placement?
[Re: Alaskan_TA]
#365961
07/07/09 03:38 AM
07/07/09 03:38 AM
Iceman01
Challenged
Challenged
Anchorage, Alaska
The door, glass and mirror are assembled so I can't get an exact measurement, but it looks to be around 30 inches.
Once I took it out of the downward-pointing bracket, I had plenty of slack. I'm pretty sure if I flip the bracket 180 degrees (point it up) everything will work fine. Hoping someone can confirm. I'm gonna dig out the shop manual and see if there is a diagram.
[Re: Iceman01]
#365962
07/08/09 11:44 AM
07/08/09 11:44 AM
Iceman01
Challenged
Challenged
Anchorage, Alaska
Flipped it around and it works fine. The bracket is bolted in through a hole in the front vertical edge of the door.
[Re: faud88]
#365970
05/11/13 08:59 PM
05/11/13 08:59 PM
Posts: 29,652 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
This way is correct. The bolt comes in from the hole in the front outer skin, you can install it with a socket.
[Re: faud88]
#365971
05/11/13 09:04 PM
05/11/13 09:04 PM
Posts: 83 CT
1932chrysler
CT
hope this helps i have 2 photos of routing on a original factory remote mirror 1971 challenger
donald
1932 Chrysler CI Sedan 1956 Pontiac Catalina Sedan All Makes & Models Are Special
