how many quarts of gear oil in a Dana 60 #365371
07/03/09 04:43 PM
07/03/09 04:43 PM
Nazareth,Pa.
JACKSON Offline OP
JACKSON  Offline OP
Nazareth,Pa.
i hearing too many different opinions on how many quarts of gear oil to put in a race only car.
how many quarts and which kind are you using? thanks Larry
Re: how many quarts of gear oil in a Dana 60 [Re: JACKSON] #365372
07/03/09 07:33 PM
07/03/09 07:33 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I use 2 quarts of Mobil 1 75W90.
Re: how many quarts of gear oil in a Dana 60 [Re: Leigh] #365373
07/03/09 08:06 PM
07/03/09 08:06 PM
i was going to try synthetic in my new dana 60
wonder if it will make any difference in performance?
i use 2 quarts as well.
Re: how many quarts of gear oil in a Dana 60 #365374
07/03/09 08:10 PM
07/03/09 08:10 PM
Tampa Florida
dc426 Offline
gotta keep'm separated
dc426  Offline
Tampa Florida
Probably make it leak worse than it already is
DC
Post deleted by Defbob [Re: dc426] #365375
07/03/09 09:13 PM
07/03/09 09:13 PM
Re: how many quarts of gear oil in a Dana 60 #365376
07/03/09 09:24 PM
07/03/09 09:24 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
If your combination picks up between long, extended rounds, it's a nice addition for less variables. I've never experienced any leakage.
Re: how many quarts of gear oil in a Dana 60 [Re: JACKSON] #365377
07/04/09 12:18 AM
07/04/09 12:18 AM
Mopar use to put on drag seminars back in the day before they went BK the first time, they always advocated running one quart of gear lube in both the Dana 60 and the 8 3/4 for drag race only cars. The explantion was that the one quart was way more than adequate for lubrication at the track and the additional fluid in the rears was for noise containment and long, hard drives across country during the summer
Re: how many quarts of gear oil in a Dana 60 [Re: JACKSON] #365378
07/04/09 08:38 AM
07/04/09 08:38 AM
Rittman Ohio
fourgearsavoy Online tonguue
fourgearsavoy  Online Tonguue
Rittman Ohio
What about when you have an Ultimate60 cover?Does it hold more oil? The level plug sits pretty far above the axle centerline.
Gus
64 Plymouth Savoy
Dana 60
Re: how many quarts of gear oil in a Dana 60 [Re: fourgearsavoy] #365379
07/04/09 02:37 PM
07/04/09 02:37 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
Gus
Yes it does hold more, almost three quarts. I use Royal Purple 85W-140 no leaks and my rear end seems happy and cool.
Re: how many quarts of gear oil in a Dana 60 [Re: cudabunch] #365380
07/04/09 03:20 PM
07/04/09 03:20 PM
Gus
GARY,thats some heavy oil. i think that might have some extra drag on your rear.
i think the royal purple 75w -90 might have been a better choice.
Re: how many quarts of gear oil in a Dana 60 #365381
07/04/09 03:32 PM
07/04/09 03:32 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
Gus
I know, but Iam crazy about fluids and in my mind it wont break if there is alot of thick stuff in there.Iam not a real racer if my car breaks down,I put it in the trailer and watch.But Iam happy.
Re: how many quarts of gear oil in a Dana 60 #365382
07/05/09 09:36 AM
07/05/09 09:36 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
The one thing we have noticed since we started using synthetic gear oil in our Dana 60 is the first run of the day is not always slower like it used to be.
Good Luck,
Bill
Re: how many quarts of gear oil in a Dana 60 #365383
07/05/09 12:04 PM
07/05/09 12:04 PM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
mineral here
Same here
