Re: can anyone cut me a indy valley cover in half?
[Re: fullmetaljacket]
#363880
07/02/09 12:05 PM
07/02/09 12:05 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
I've got one for a B motor with the window in it, don't know what brand it is, but it works good!
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
[Re: cudabunch]
#363883
07/02/09 04:26 PM
07/02/09 04:26 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
I cant see why you want one cut when you can buy one from Andy or Indy.I have the Indy one and it works great, no leaks.
If it starts leaking what are you gonna do, pull the heads? If you mill the sides like BG said then that would be ok, but it seems like it would need a huge amount of RTV doing it that way. ![](/ubbthreads/images/graemlins/shruggy.gif)
Mine is not setup for checking the lifters though, I never thought of that.
[Re: AndyF]
#363884
07/02/09 04:46 PM
07/02/09 04:46 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Sounds like you need a price list from AR Engineering? That way you'll have the good stuff for the special customers.
We have used some of you stuff that we have gotten from other vendors and like the quality of your work.We would be interested in being a WD if you offer such a program. ![](/ubbthreads/images/graemlins/bow.gif)
[Re: ProSport]
#363885
07/02/09 04:57 PM
07/02/09 04:57 PM
Posts: 1,217 Wellington, FL
cudabunch
Wellington, FL
If you do get a leak on the solid one,all you have to do is to slide it foward and clean it up and reseal.You dont have to remove the heads.The one that Andy and Indy has is so easy to check on inside its crazy to use anything else.
[Re: B G Racing]
#363888
07/03/09 08:20 AM
07/03/09 08:20 AM
Posts: 16,932 NC
440Jim
NC
Milling the lower edge of the champher does not increase the gap at the top that meets the head,use the same bead of silicone and just add an extra dab at the 4 corners.We do this to all Indy covers,even the two piece with o problems or leaks.
Bob, does this pic help explain your method? i.e. cut at the vertical black line.
[Re: RonP]
#363890
07/03/09 04:02 PM
07/03/09 04:02 PM
my engine builder arc got me one and cut it, just have to go see it and get it when i pick up my 63 plymouth, just redid my suspension over and let me say he does some serious work. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: cudabunch]
#363892
07/03/09 04:40 PM
07/03/09 04:40 PM
went with a chassis engineering triple adjustable outlaw ladder bar with strange double adjustable coil overs with hypercoil. new motor is going in very soon so the cal tracs came out. i want to see the difference from cal tracs to ladder bars in this car.
[Re: 440Jim]
#363894
07/03/09 06:00 PM
07/03/09 06:00 PM
B G Racing
Eighty Four, PA
An can be done very cheaply. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: AndyF]
#363895
07/04/09 10:27 PM
07/04/09 10:27 PM
Posts: 205 Illinois
gearhead01
Illinois
Andy:
Do you think you will have a "B" block version?
Thank you, John
1971 Satellite Sebring Plus - 14.46 @ 95.43 1977 Road Runner - N/B 11.02@ 119 Drag Radials
[Re: AndyF]
#363896
07/04/09 11:26 PM
07/04/09 11:26 PM
Posts: 3,619 Norwich CT USA
Defbob
Norwich CT USA
You can get those billet valley plates from Mancini Racing, Hughes Engines, etc. Part number is AR182. They come with a gasket but they are also machined for an o-ring if you want to go that way. RB only though. There isn't a version for the B motor.
And Hemi's ![](/ubbthreads/images/graemlins/whistling.gif)
[Re: RyanJ]
#363898
07/06/09 03:07 PM
07/06/09 03:07 PM
Posts: 1,633 Jacksonville, NC
RonP
Jacksonville, NC
Is there anything "wrong" with the INDY version with the removable center? I just ordered one for my new 448 this morning.... Seems like everyone is trying to run something different for some reason? This BB crap is all new to me...
Ryan, nothing wrong at all. The removeable center is nice, but we milled the edges on mine just incase the whole thing needed removed. As luck would have it I had an issue that required me to remove the whole cover because the opening wasn't enough for what I needed to do. Using BG's method made it easy to pull the whole cover up out. ![](/ubbthreads/images/graemlins/Twocents.gif)
