Page 2 of 3 1 2 3
Re: can anyone cut me a indy valley cover in half? [Re: fullmetaljacket] #363880
07/02/09 12:05 PM
07/02/09 12:05 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
I've got one for a B motor with the window in it, don't know what brand it is, but it works good!
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: can anyone cut me a indy valley cover in half? [Re: Slingshot383] #363881
07/02/09 12:17 PM
07/02/09 12:17 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
I would suggest either Indy's or Andy's plates for a roller cam engine.AS for quality machined verses cast,Andy's gets a I don't know the cost difference
Re: can anyone cut me a indy valley cover in half? [Re: B G Racing] #363882
07/02/09 01:38 PM
07/02/09 01:38 PM
AndyF Online content
AndyF  Online Content
Sounds like you need a price list from AR Engineering? That way you'll have the good stuff for the special customers.
Re: can anyone cut me a indy valley cover in half? [Re: cudabunch] #363883
07/02/09 04:26 PM
07/02/09 04:26 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I cant see why you want one cut when you can buy one from Andy or Indy.I have the Indy one and it works great, no leaks.
If it starts leaking what are you gonna do, pull the heads? If you mill the sides like BG said then that would be ok, but it seems like it would need a huge amount of RTV doing it that way.
Mine is not setup for checking the lifters though, I never thought of that.
Re: can anyone cut me a indy valley cover in half? [Re: AndyF] #363884
07/02/09 04:46 PM
07/02/09 04:46 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We have used some of you stuff that we have gotten from other vendors and like the quality of your work.We would be interested in being a WD if you offer such a program.
Re: can anyone cut me a indy valley cover in half? [Re: ProSport] #363885
07/02/09 04:57 PM
07/02/09 04:57 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
If you do get a leak on the solid one,all you have to do is to slide it foward and clean it up and reseal.You dont have to remove the heads.The one that Andy and Indy has is so easy to check on inside its crazy to use anything else.
Re: can anyone cut me a indy valley cover in half? [Re: cudabunch] #363886
07/02/09 07:55 PM
07/02/09 07:55 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Milling the lower edge of the champher does not increase the gap at the top that meets the head,use the same bead of silicone and just add an extra dab at the 4 corners.We do this to all Indy covers,even the two piece with o problems or leaks.
Re: can anyone cut me a indy valley cover in half? [Re: B G Racing] #363887
07/02/09 08:50 PM
07/02/09 08:50 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
BG makes good points. Every time I mocked up the Indy Tray the Beveled part liked a mile from touching the heads any way... I have always had to build up a large thick layer of sealer for it to work.
I picked up My cover used, and always figured some one may have milled it or something....
Pretty much fit like OJ's Glove LOL
Re: can anyone cut me a indy valley cover in half? [Re: B G Racing] #363888
07/03/09 08:20 AM
07/03/09 08:20 AM
NC
440Jim Offline
440Jim  Offline
NC
Bob, does this pic help explain your method? i.e. cut at the vertical black line.
Re: can anyone cut me a indy valley cover in half? [Re: 440Jim] #363889
07/03/09 09:44 AM
07/03/09 09:44 AM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
Bob, did mine while I had my engine there and I have no problems with sealing it. Unfortunatley I had to remove the cover completely once since then and it went back together no problem with no leaks.
Re: can anyone cut me a indy valley cover in half? [Re: RonP] #363890
07/03/09 04:02 PM
07/03/09 04:02 PM
Anonymous OP
Anonymous OP
my engine builder arc got me one and cut it, just have to go see it and get it when i pick up my 63 plymouth,
just redid my suspension over and let me say he does some serious work.
Re: can anyone cut me a indy valley cover in half? #363891
07/03/09 04:19 PM
07/03/09 04:19 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
Congrats on the cut. What suspension did you get?
Re: can anyone cut me a indy valley cover in half? [Re: cudabunch] #363892
07/03/09 04:40 PM
07/03/09 04:40 PM
Anonymous OP
Anonymous OP
went with a chassis engineering triple adjustable outlaw ladder bar with strange double adjustable coil overs with hypercoil.
new motor is going in very soon so the cal tracs came out.
i want to see the difference from cal tracs to ladder bars in this car.
Re: can anyone cut me a indy valley cover in half? #363893
07/03/09 04:44 PM
07/03/09 04:44 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
Sounds great and hope it works well.
Re: can anyone cut me a indy valley cover in half? [Re: 440Jim] #363894
07/03/09 06:00 PM
07/03/09 06:00 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
An can be done very cheaply.
Re: can anyone cut me a indy valley cover in half? [Re: AndyF] #363895
07/04/09 10:27 PM
07/04/09 10:27 PM
Illinois
gearhead01 Offline
gearhead01  Offline
Illinois
Andy:
Do you think you will have a "B" block version?
Thank you, John
1971 Satellite Sebring Plus - 14.46 @ 95.43
1977 Road Runner - N/B 11.02@ 119 Drag Radials
Re: can anyone cut me a indy valley cover in half? [Re: AndyF] #363896
07/04/09 11:26 PM
07/04/09 11:26 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
You can get those billet valley plates from Mancini Racing, Hughes Engines, etc. Part number is AR182. They come with a gasket but they are also machined for an o-ring if you want to go that way. RB only though. There isn't a version for the B motor.
And Hemi's
Re: can anyone cut me a indy valley cover in half? #363897
07/06/09 03:01 PM
07/06/09 03:01 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Is there anything "wrong" with the INDY version with the removable center? I just ordered one for my new 448 this morning.... Seems like everyone is trying to run something different for some reason? This BB crap is all new to me...
Re: can anyone cut me a indy valley cover in half? [Re: RyanJ] #363898
07/06/09 03:07 PM
07/06/09 03:07 PM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
Ryan, nothing wrong at all. The removeable center is nice, but we milled the edges on mine just incase the whole thing needed removed. As luck would have it I had an issue that required me to remove the whole cover because the opening wasn't enough for what I needed to do. Using BG's method made it easy to pull the whole cover up out.
Re: can anyone cut me a indy valley cover in half? [Re: RonP] #363899
07/06/09 03:44 PM
07/06/09 03:44 PM
Riverside, California
Lil Demon Offline
Lil Demon  Offline
Why not just sell the Indy piece and buy a Bulldog one from Muscle Motors? I think they have all the old stock of them.
Page 2 of 3 1 2 3
