440 push rods #363818
07/01/09 06:40 PM
07/01/09 06:40 PM
Shippensburg,PA
66Coronet440 Offline OP
Shippensburg,PA
has anyone run stealth heads with 440 source rockers on a 440 with a mopar hyd. cam and had problems finding the correct push rods? i'm looking at having a custom set made since i can't find any close to the length i need. has anyone else run into this?
Re: 440 push rods [Re: 66Coronet440] #363819
07/01/09 08:26 PM
07/01/09 08:26 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I have Stealths with iron rockers.I just used Crane 3/8 alloy for solid s.No problems with mine.The adjuster screws are almost all perfect.Rocky
Chrysler Firepower
Re: 440 push rods [Re: therocks] #363820
07/01/09 08:40 PM
07/01/09 08:40 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
It's normal to need custom pushrods for aftermarket heads and rockers.
Re: 440 push rods [Re: Quicksilver440] #363821
07/01/09 08:51 PM
07/01/09 08:51 PM
Boise Idaho
Boise Chall Offline
Boise Chall  Offline
Boise Idaho
I have that same setup I had to order my push tubes but they are not custom made. in a normal town that has a store that caters to the Mopar crowd not just chevy and ford they should have them on the shelf. I do remember having to have all of my push tube slots in the heads moved over because the push tubes would not line up between the rocker and the lifter correctly. If you still have your heads off mock them up and check this before you waste a set of gaskets
Re: 440 push rods [Re: 66Coronet440] #363822
07/04/09 09:45 AM
07/04/09 09:45 AM
JOPLIN MO 64804
RBDART1 Offline
RBDART1  Offline
JOPLIN MO 64804
WHAT SIZE DO YOU NEED? AND ARE YOU USING ADJUSTABLE ROCKERS OR STAMPED STEEL FACTORY STYLE? MAY BE ABLE TO HELP, RAN INTO THIS PROB AWHILE BACK...YOU CAN E-MAIL ME AT; kgull440@yahoo.com
