Help with Pinion angle
#363538
07/01/09 11:33 AM
07/01/09 11:33 AM
Posts: 4,288 Danville, NH
Mopar_Mike
Danville, NH
After breaking my tailshaft (different post) I went to check my pinion angle. The car (67 Coronet RT) had superstock springs in it with an 8 3/4. I switched to caltracs with the monoleaf and +1" ride height.
I put the magnetic angle finder on the 8 3/4 where the snuber would be. It was +3 degrees
I put the finder on the tailshaft, upside down, because the trans is still in the car. It read +1 degree.
So, if I am reading this right, +1 at the trans and +1 at the pinion gives me 0 straight line. So, since the pinion is still +2, I need to get it to -3 (optimal according to caltracs). So I need to reduce the angle negatively by 5 degrees?
Thanks for your help.
RS23L7 4-Speed
Re: Help with Pinion angle
[Re: Mopar_Mike]
#363539
07/01/09 11:51 AM
07/01/09 11:51 AM
Posts: 16,479 Canada
CrAzYMoPaRGuY
Canada
Set up your operating angle and THEN set your pinion angle. If your trans drops 1 degree at the tail and your pinion is nose up 1 degree then roll your pinion down as many degrees of pinion angle as you want. Maybe a few experienced Caltrac users here have a strong opinion on what the actual pinion angle should be.... PIPE UP if you do!
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#363540
07/01/09 11:58 AM
07/01/09 11:58 AM
Posts: 2,930 Odessa, Tx.
cudarex
Odessa, Tx.
I believe Calvert wants 3-4 degrees
[Re: cudarex]
#363544
07/01/09 12:43 PM
07/01/09 12:43 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
if the tailshaft is pointing up 1 degree (nose up) and the pinion is 3 degrees nose up then your pinion angle is 4 degrees nose up.
Dr Diff's advice: make them parallel (i.e. tailshaft nose down, pinion nose up) then roll the pinion down X degrees to get X degrees of pinion angle.
[Re: patrick]
#363545
07/01/09 01:14 PM
07/01/09 01:14 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
Dr Diff's advice: make them parallel (i.e. tailshaft nose down, pinion nose up) then roll the pinion down X degrees to get X degrees of pinion angle. That's too easy... *Running off to the garage *
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: Adobedude]
#363546
07/01/09 01:30 PM
07/01/09 01:30 PM
Mopar_Mike
Danville, NH
Sorry.. I remeasured and have different numbers..
The 8 3/4 housing is facing down (-3 degrees)
The transmission tail shaft is facing up (+2 degrees)
RS23L7 4-Speed
[Re: Sport440]
#363549
07/01/09 02:49 PM
07/01/09 02:49 PM
cudarex
Odessa, Tx.
If your trans is pointing up 2* your pinion would need to be Down 2* to be parrelel.
Since pinion is Down 3* Your pinion angle is sitting at 1* down. mike
So, based on those numbers he needs to rotate the pinion down another 3-4 degrees which would give a total of 4-5 degrees down for the pinion.
[Re: cudarex]
#363550
07/01/09 04:09 PM
07/01/09 04:09 PM
patrick
Grand Haven, MI
caltracs don't need that much angle....
also, are you checking it with all 4 tires on the ground, or the rear end jacked up? if it's not on the ground, or on a 4 post lift, or on 4 ramps with the vehicle weight on the tires as it sits on the ground, your angle measurements might be off, as the rear suspension is unloaded with the rear up on jackstands (even more if the stands are under the subframe and the rear is hanging).
