Just make sure if you plumb it into one of the valvecovers and put the vacuum pump pick up in a valvecover that you put them ini opposite covers. IE inlet on pass cover, gauge tap on Dr side. That way you will ensure you are making vacuum in the crankcase not just that cover
I woudl also recommend you put it on the inside edge of the valvecover as a pickup point. A B1 leaves a fair amouont of oil up top, if you try the front it will suck oil on decel. Here is where mine is. Hard to see but I used the Star fitting and it is on the drivers side cover.
