Another vaccuum pump question (gauge plumbing) #362864
06/30/09 03:55 PM
06/30/09 03:55 PM
Kentucky
sc301v Offline OP
sc301v  Offline OP
Kentucky
Since i have all my new vaccuum pump stuff ready to install where is the best place to plumb up for a gauge.
I have one to put in the dash on the car so i will be running a line back to where ever i tap into.
Re: Another vaccuum pump question (gauge plumbing) [Re: sc301v] #362865
06/30/09 04:01 PM
06/30/09 04:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I just ran the gauge line to the back of the valve
cover
Re: Another vaccuum pump question (gauge plumbing) [Re: MR_P_BODY] #362866
06/30/09 05:33 PM
06/30/09 05:33 PM
oregon
greendart408 Offline
oregon
cover
x3
Re: Another vaccuum pump question (gauge plumbing) [Re: greendart408] #362867
06/30/09 10:26 PM
06/30/09 10:26 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Fuel pump block-off plate...........
Re: Another vaccuum pump question (gauge plumbing) [Re: markz528] #362868
06/30/09 11:09 PM
06/30/09 11:09 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I use a fitting in the top of the valve cover, near the front of the motor, thinking oil might find its way to the back under acceleration. Purely theoretical.
Re: Another vaccuum pump question (gauge plumbing) [Re: topside] #362869
06/30/09 11:19 PM
06/30/09 11:19 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Just make sure if you plumb it into one of the valvecovers and put the vacuum pump pick up in a valvecover that you put them ini opposite covers. IE inlet on pass cover, gauge tap on Dr side. That way you will ensure you are making vacuum in the crankcase not just that cover
I woudl also recommend you put it on the inside edge of the valvecover as a pickup point. A B1 leaves a fair amouont of oil up top, if you try the front it will suck oil on decel. Here is where mine is. Hard to see but I used the Star fitting and it is on the drivers side cover.
