alternator wiring question.... #362804
06/30/09 03:09 PM
06/30/09 03:09 PM
Indiana
F6F6Dodge Offline OP
Indiana
I can't remember how to hook up the wires back on to my alternator....I have 2 "male" terminals sticking out of the alternator and 2 "female" connectors from my wiring harness....a blue wire and a green wire....
The blue wire also hooks to the +(positive)side of the coil and the green one goes to the -(negative) side of the coil..
So, my question is::: which wire goes to which terminal on the alternator???? or does it even matter???
Does this make any sense to anyone??? Thanks
Re: alternator wiring question.... [Re: F6F6Dodge] #362805
06/30/09 03:24 PM
06/30/09 03:24 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Doesn't matter which way the field wires go.
Re: alternator wiring question.... [Re: OzHemi] #362806
06/30/09 03:28 PM
06/30/09 03:28 PM
Indiana
Indiana
Thanks....I wasn't sure....
Re: alternator wiring question.... [Re: F6F6Dodge] #362807
06/30/09 03:56 PM
06/30/09 03:56 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Dual Field
Re: alternator wiring question.... [Re: F6F6Dodge] #362808
06/30/09 04:17 PM
06/30/09 04:17 PM
You might want to check that as the green field wire would not be going to the coil negative or anywhere other than from (as said) either field lead to the VR ground terminal(the one on the right) when the pyramid is facing up.
