Re: 318 Stroker ??
[Re: kams]
#36279
04/29/07 06:00 AM
04/29/07 06:00 AM
stroking with a 360 crank is not very cost effective considering the cost of a full 360 would be cheaper and yield mor inches.this may not be true however if you are a machinist?stroker kits for the sbm are around 1300 with excellent rods,forged pistons ect and yield @ 390 inches with a 318.
it sounds like you are somewhat new to mopars.ill give you some great advice.build whatever motor you have with whatever parts you have.all mopar engines run great and that includes a 318.there are combinations of parts that are better,but there is no bad way to put one together.enjoy whatever stuff you have and dont fret alot over trying to find a certain set of heads or intake.let me know what you have,what you are trying to do, and the budget in mind and ill give you some ideas.
Re: 318 Stroker ??
[Re: kams]
#36280
04/29/07 10:30 AM
04/29/07 10:30 AM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
Henslee makes 402's out of them. Hotroddave40 is building one. He sonic checked 2 340's and a 67 318. Guess which one was thicker?
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: 318 Stroker ??
[Re: kams]
#36284
05/01/07 07:36 AM
05/01/07 07:36 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
There has been a post on this on the Forabodiesonly.com site. Like Dog said. there is a cast piston that will drop in, and when I did a search, there was a set on Ebag for $130 with rings. It can be done cheap, but cheap is a relative thing. You will get what you pay for in terms of machine work. In any regard, it can be done.
Re: 318 Stroker ??
#36285
01/15/09 02:41 PM
01/15/09 02:41 PM
I want to stroke a 1972 charger 400 block I want to use a old 440 crank . grind the crank to fit . and use the heads that I have maybe get them ported .Top it off with the old thermo qaud carb .I want to do this for as cheap as possible . Any ideas?
Re: 318 Stroker ??
#36286
01/15/09 03:14 PM
01/15/09 03:14 PM
DaytonaTurbo
Manitoba, Canada
Any ideas?
Yeah here's one. Start a new thread instead of bringing back a thread that's been dead for two years. A 440 crank in a 400 block = 451, but the crank journals need to be turned down as well as the counter weights on the crank need trimming IIRC.
