Line Lock Doesn't Hold Properly #362140
06/29/09 11:35 PM
06/29/09 11:35 PM
N
NJK66 Offline OP
super street
NJK66  Offline OP
super street
N
I just installed a Biondo line lock on my car. The solenoid clicks and engages the front brakes but when you try to do a burn out the power of the rear wheels overcome the front brakes and the front wheels start to roll. This car only makes about 450 HP. I backed off the rear brake adjustment, lines are bled properly (good firm pedal). I even removed the proportioning valve thinking that was the problem. All the lines going to the front brakes are new as well as the master cylinder, calipers, brake pads, and line lock. Any suggestions?
Re: Line Lock Doesn't Hold Properly [Re: NJK66] #362141
06/29/09 11:37 PM
06/29/09 11:37 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
Is the line lock new?
I have heard they have a life span. Mine still works, and is 5 years old. Pretty light use.
Re: Line Lock Doesn't Hold Properly [Re: NJK66] #362142
06/29/09 11:40 PM
06/29/09 11:40 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
What happens when you do a power brake without the line lock? Will power of the rear wheels overcome the front brakes and the front wheels start to roll?
If it did not hold it before it is not going to with the line lock now.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Line Lock Doesn't Hold Properly [Re: HealthServices] #362143
06/30/09 12:21 AM
06/30/09 12:21 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
if you can foot brake it and have it not roll, the problem is the line lock.
can you pump the pedal any harder prior to turning the line lock on? maybe you just didn't generate enough line pressure before locking the front brakes?
**Photobucket sucks**
Re: Line Lock Doesn't Hold Properly [Re: 70Cuda383] #362144
06/30/09 10:41 AM
06/30/09 10:41 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Are the fronts rolling or sliding?
Re: Line Lock Doesn't Hold Properly [Re: stumpy] #362145
06/30/09 11:03 AM
06/30/09 11:03 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Two ways to go about installing that line lock.....The first way is how I did it on my one 70 Charger. The second way I think is better.
1) install it on the front, two real good deep pumps and hit the switch, you should not be rolling.
2) Install it on the rear brakes, hit your switch to lock the solenoid shut and your foot will be applying a stronger pressure on the front brakes than a line lock could. You have foot pressure versus closed pressure. Personally, I should have done it this way but you live and learn.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Line Lock Doesn't Hold Properly [Re: Pyper70] #362146
06/30/09 11:14 AM
06/30/09 11:14 AM
ar.
bobs69 Offline
bobs69  Offline
ar.
If you put the line lock on the rear you may want to put a light on the switch to make sure you turn it off. Otherwise you will have no rear brakes down track.
Re: Line Lock Doesn't Hold Properly [Re: bobs69] #362147
06/30/09 11:50 AM
06/30/09 11:50 AM
So Cal
So Cal
Line locks use momentary switches as long as you have a finger on the switch it is 'on' once released it is 'off'.
Re: Line Lock Doesn't Hold Properly [Re: NJK66] #362148
06/30/09 12:16 PM
06/30/09 12:16 PM
Jersey shore
Gary67 Offline
super street
Gary67  Offline
super street
Jersey shore
Hold the button on and pump through the line lock..My Biondo did the same thing till I got the advice from a long time racer..You can pump through some linelocks...Thats why they label the ports, you can force the check off the seat on the "in" port, but it will positive check on the brake/out port...
Re: Line Lock Doesn't Hold Properly [Re: HealthServices] #362149
06/30/09 12:54 PM
06/30/09 12:54 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Yeah...what he said....I had a momentary switch located on my shifter and my index finger would hold it down as I went through the burnout stages
I would have a primary 2-pole on/off that would have to be switched on for the secondary shifter button to engage the solenoid
Re: Line Lock Doesn't Hold Properly [Re: Pyper70] #362150
06/30/09 01:16 PM
06/30/09 01:16 PM
ar.
bobs69 Offline
bobs69  Offline
ar.
A lot of racers use a toggle switch so it's either on or off.
Re: Line Lock Doesn't Hold Properly [Re: bobs69] #362151
06/30/09 01:44 PM
06/30/09 01:44 PM
So Cal
So Cal
Although people do it, that would be the inproper way of installing it then.
  • Power from a fused circuit
  • flip switch to power the circuit (not everyone does this part)
  • momentary switch (normally open in series) to engage line lock.
I don't think I have a current rule book but I believe it states you have to use a momentary switch as well.
Re: Line Lock Doesn't Hold Properly [Re: HealthServices] #362152
06/30/09 01:53 PM
06/30/09 01:53 PM
ar.
bobs69 Offline
bobs69  Offline
ar.
Didn't say it was legal. Just said people do it.
Re: Line Lock Doesn't Hold Properly [Re: bobs69] #362153
06/30/09 01:57 PM
06/30/09 01:57 PM
So Cal
So Cal
Basically I'm saying it is the improper way of doing it. Do it right the first time and you don't have worry about it.
Re: Line Lock Doesn't Hold Properly [Re: NJK66] #362154
06/30/09 08:55 PM
06/30/09 08:55 PM
N
NJK66 Offline OP
super street
NJK66  Offline OP
super street
N
Here is the answers to the questions asked by those who responded:
1) The Biondo Line Lock is brand new.
2) I have tried hitting the switch and pumping the brakes after the switch is engaged.
3) I also pumped the brakes prior to setting the line lock. No change.
4) When the line lock is set, the front wheels will turn when the rear wheels over power the fronts.
5) When I use the foot brake only (no line lock)the fronts will lock down and slide on the pavement when the rear wheels put out enough steam to move the car.
6) The master cylinder, calipers, pads, plumbing, and line lock are all new. I have a real good firm pedal so I am asuming the brakes are bled properly.
I called Biondo today and they said that I have done everything right as far as installation. They are sending me another line lock unit to try. I'll let you guys know what happens. If anyone else has any suggestions, feel free to respond.
Thanks to all who responded.
Re: Line Lock Doesn't Hold Properly [Re: NJK66] #362155
06/30/09 10:41 PM
06/30/09 10:41 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I had a similar occurrence on my car - nothing new or different, though - and it was because I didn't push the pedal hard enough. Try it after STANDING on the brake pedal like you're trying to bend it, and see if there's any difference. Put some water under the rear tires, too.
Re: Line Lock Doesn't Hold Properly [Re: bobs69] #362156
07/01/09 11:46 PM
07/01/09 11:46 PM
dave571 Offline
dave571  Offline
I've always ran a toggle switch.
No one has ever asked me about my line lock at tech, except for where it was mounted in relation to the proportioning valve.
I think most guys have a routine they follow at the line. Once you are set in doing the routine, it always goes that way
Re: Line Lock Doesn't Hold Properly [Re: NJK66] #362157
07/02/09 10:31 AM
07/02/09 10:31 AM
N
NJK66 Offline OP
super street
NJK66  Offline OP
super street
N
I tried watering down the slicks and the ground they sat on. I thought I was pushing down on the pedal pretty hard. I will try your advice and really push hard down on the pedal. Thanks
