Small Block Eddy Autolites? #362058
06/29/09 10:27 PM
06/29/09 10:27 PM
Ohio
Lil Wedge Offline OP
Ohio
Has anyone ever tried Autolite 3933 in the Small block? I have a small clearance issue with 3911's and was wondering?
Re: Small Block Eddy Autolites? [Re: Lil Wedge] #362059
06/29/09 11:13 PM
06/29/09 11:13 PM
River Falls, WI
urdustd Offline
urdustd  Offline
River Falls, WI
I'm not sure, but I run the 3924's without any problem.
What's the reason you are running the 3933's?
Re: Small Block Eddy Autolites? [Re: urdustd] #362060
06/30/09 08:51 AM
06/30/09 08:51 AM
3924's here too...
Re: Small Block Eddy Autolites? [Re: Lil Wedge] #362061
06/30/09 09:38 AM
06/30/09 09:38 AM
Burlington,Ont.
77DragracerR/T Offline
Burlington,Ont.
I have the AR3934's in mine and no problem with eddy heads.
77 Aspen R/T 60'@1.41 10.76 @ 123.26
http://www.youtube.com/watch?v=Eya3Ue8KoZk
Re: Small Block Eddy Autolites? [Re: urdustd] #362062
06/30/09 11:43 AM
06/30/09 11:43 AM
Ohio
Ohio
3933'S were just a suggestion by someone. If I don't double washer the 3911's I will have a very slight shiney place at the end of the tip of the strap. I tried ngk's once with the full strap, about a month later I lost 4 tips of the straps, like they were cut cleanly back near the curve, in the 4th round of Div. 3 Bracket finals, and you know what that will do to your day.Just trying to get a shorter plug.
Re: Small Block Eddy Autolites? [Re: Lil Wedge] #362063
06/30/09 01:01 PM
06/30/09 01:01 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
The NGK 5671A-8, stock# 4554 have a none projected tip (short strap)...thats what I use with my eddys.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Small Block Eddy Autolites? [Re: FlyFish] #362064
06/30/09 05:41 PM
06/30/09 05:41 PM
Ohio
Ohio
Thanks for all the replies!
