Smoke inside the engine.. UPDATED #361986
06/29/09 08:59 PM
06/29/09 08:59 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
What do you guys think about using a smoke machine to find those pesky oil leaks? I have an oil leak either at the rear main, the oil filter adapter or possibly a valve cover..
A friend mechanic recommended using a smoke machine to flush out the oil leak.. I've never heard of this before and my first thought is can we create enough psi to force a leak and wanted to find out if others has done this before???
Re: Smoke inside the engine.. [Re: Jeepmon] #361987
06/29/09 09:05 PM
06/29/09 09:05 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Brake clean and a drop lite
Re: Smoke inside the engine.. [Re: emarine01] #361988
06/29/09 09:11 PM
06/29/09 09:11 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
The only time I notice the leak is when the car is under load and at high rpm...
After 3 pulls on the dyno, there was an ounce or two on the ground (right rear of the motor) and the last time down the strip, I was told there was white smoke visible at about 1/2 track..
It wont be until this weekend that we can get the car up on the rack and we still have an open mind as to whats causing the smoke... But my buddy recommended trying this first..
Re: Smoke inside the engine.. [Re: Jeepmon] #361989
06/29/09 09:14 PM
06/29/09 09:14 PM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
Get a little tube of the ultraviolet detector that you just dump in your engine oil and search with your UV glasses and black light after it runs. Same way we check for AC leaks at the shop, but they ake this for all different fluids, Oil, trans, coolant, brake fluid etc.
Re: Smoke inside the engine.. [Re: wheelsup68dart] #361990
06/29/09 09:23 PM
06/29/09 09:23 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
The place where I get to work on my car is a 4 bay auto repair shop and when closed, I have full run of the shop... They do have the U/V set up and it has been offered, but my buddy seems to think the smoke trick is a better way...
Personally speaking, I'm fascinated with the idea of using smoke.. if it works like we think it should, then it would be an awesome diagnostic tool.. So I wanted to ask you guys if you've ever used it before and what are the do's and dont's??
Re: Smoke inside the engine.. [Re: Jeepmon] #361991
06/29/09 09:30 PM
06/29/09 09:30 PM
Land of Lost
flatlinedude Offline
No pulse
No pulse
Land of Lost
Seeing as how you're obviously set on using your idea. Why don't you just report back to us on how well it worked? I'm interested in knowing.
Carol: "Wow! He's really fast, isn't he?!" John: "Yeah... but he's stupid."
Re: Smoke inside the engine.. [Re: flatlinedude] #361992
06/29/09 09:42 PM
06/29/09 09:42 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
smoke machines work very well for many different things use them for finding vacum leaks,oil leaks,leaks in the evap system,and even wind noises.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Smoke inside the engine.. [Re: dusturbd340W5] #361993
06/30/09 01:29 AM
06/30/09 01:29 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
before you go that far...you said at 1/2 track?
check your dipstick. make sure it's held down tight. mine was loose and under full throttle, pressure would build up inside the crankcase and pop it out, spewing oil all over the headers making smoke...but It didn't smoke until the end of a run down the street, I'd give it WOT and not get any smoke till the end of 3rd gear.
**Photobucket sucks**
Re: Smoke inside the engine.. [Re: 70Cuda383] #361994
06/30/09 01:30 AM
06/30/09 01:30 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
We love tyo play with the smoke machine
Re: Smoke inside the engine.. [Re: Al_Alguire] #361995
06/30/09 06:37 AM
06/30/09 06:37 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i've used the dye method to trace an oil leak in the past. it was brilliant. thought i had a rear main leak but turned out the valley cover weeped at the front & the oil tracked along the head gasket & dripped off the back of the head onto the trans joint. spent a long time looking in the wrong place. if you had a small oil weep would smoke be able to detect that?
Re: Smoke inside the engine.. [Re: Jeepmon] #361996
06/30/09 06:45 AM
06/30/09 06:45 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
Smoke machine will do nothing to find leaks such as the rear main or oil filter adapter, it'd have to fill the oil passages .
You said it happens under full load mainly, 5 bucks says it's blow-by coming out of the valve cover at the breather.
Re: Smoke inside the engine.. [Re: CokeBottleKid] #361997
06/30/09 07:55 AM
06/30/09 07:55 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
... 5 bucks says it's blow-by coming out of the valve cover at the breather.
Mine does that on occasion.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Smoke inside the engine.. [Re: CokeBottleKid] #361998
06/30/09 07:57 AM
06/30/09 07:57 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
do a compression check. I had an engine doing the same thing. only blew out oil from the front somewhere after a high rpm romp. then started smoking a bit. then noticed a lot of blowby. found the leak was coming out the vent on the fuel pump and found low compression on one cylinder. broke the top edge off a piston (probably detonation) and messed up a ring.
Re: Smoke inside the engine.. [Re: flatlinedude] #361999
07/04/09 09:07 PM
07/04/09 09:07 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
The smoke machine worked GREAT.. and it was actually kinda fun playing with it..
Ok, so the symptoms were oil leaking, towards the right rear of the SB motor, but only on hard accel or load..
Come to find out the RTV we used to seal the back edge of the intake manifold gave out and smoke was coming out of there just as plain as can be.. Next weekend we will pull off the intake and see why the RTV gave out..
Since we had the smoke machine out and warmed up, we decided to play around a little and found that there is a vacuum leak between the booster and the master cylinder, but only when the pedal is depressed.. Is this normal and is there supposed to be a gasket between the two?
Lastly, for those of you that have access to a smoke machine, its works very well for finding leaks..
Post deleted by Defbob [Re: Al_Alguire] #362000
07/04/09 09:10 PM
07/04/09 09:10 PM
Re: Smoke inside the engine.. #362001
07/04/09 09:13 PM
07/04/09 09:13 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
him too
That poor kid!!
Re: Smoke inside the engine.. [Re: Jeepmon] #362002
07/05/09 10:14 AM
07/05/09 10:14 AM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
does it have evac pan system ,check ball valves ?crankcase pressure under load high rpm causes leaks .
check breather caps some foam or wire mesh becomes loaded blocked see if dip stick creeps out under load .
don
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
