Smoke inside the engine.. UPDATED
#361986
06/29/09 08:59 PM
06/29/09 08:59 PM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
What do you guys think about using a smoke machine to find those pesky oil leaks? I have an oil leak either at the rear main, the oil filter adapter or possibly a valve cover..
A friend mechanic recommended using a smoke machine to flush out the oil leak.. I've never heard of this before and my first thought is can we create enough psi to force a leak and wanted to find out if others has done this before???
Re: Smoke inside the engine..
[Re: wheelsup68dart]
#361990
06/29/09 09:23 PM
06/29/09 09:23 PM
Jeepmon
Sunnyvale, CA
Get a little tube of the ultraviolet detector that you just dump in your engine oil and search with your UV glasses and black light after it runs. Same way we check for AC leaks at the shop, but they ake this for all different fluids, Oil, trans, coolant, brake fluid etc.
The place where I get to work on my car is a 4 bay auto repair shop and when closed, I have full run of the shop... They do have the U/V set up and it has been offered, but my buddy seems to think the smoke trick is a better way...
Personally speaking, I'm fascinated with the idea of using smoke.. if it works like we think it should, then it would be an awesome diagnostic tool.. So I wanted to ask you guys if you've ever used it before and what are the do's and dont's??
[Re: flatlinedude]
#361992
06/29/09 09:42 PM
06/29/09 09:42 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
smoke machines work very well for many different things use them for finding vacum leaks,oil leaks,leaks in the evap system,and even wind noises.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#361993
06/30/09 01:29 AM
06/30/09 01:29 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
before you go that far...you said at 1/2 track?
check your dipstick. make sure it's held down tight. mine was loose and under full throttle, pressure would build up inside the crankcase and pop it out, spewing oil all over the headers making smoke...but It didn't smoke until the end of a run down the street, I'd give it WOT and not get any smoke till the end of 3rd gear.
**Photobucket sucks**
[Re: Jeepmon]
#361996
06/30/09 06:45 AM
06/30/09 06:45 AM
Posts: 8,180 Detroit, MI
CokeBottleKid
Detroit, MI
Smoke machine will do nothing to find leaks such as the rear main or oil filter adapter, it'd have to fill the oil passages . You said it happens under full load mainly, 5 bucks says it's blow-by coming out of the valve cover at the breather.
[Re: flatlinedude]
#361999
07/04/09 09:07 PM
07/04/09 09:07 PM
Jeepmon
Sunnyvale, CA
Seeing as how you're obviously set on using your idea. Why don't you just report back to us on how well it worked? I'm interested in knowing.
The smoke machine worked GREAT.. and it was actually kinda fun playing with it..
Ok, so the symptoms were oil leaking, towards the right rear of the SB motor, but only on hard accel or load..
Come to find out the RTV we used to seal the back edge of the intake manifold gave out and smoke was coming out of there just as plain as can be.. Next weekend we will pull off the intake and see why the RTV gave out..
Since we had the smoke machine out and warmed up, we decided to play around a little and found that there is a vacuum leak between the booster and the master cylinder, but only when the pedal is depressed.. Is this normal and is there supposed to be a gasket between the two?
Lastly, for those of you that have access to a smoke machine, its works very well for finding leaks..
Post deleted by Defbob
[Re: Al_Alguire]
#362000
07/04/09 09:10 PM
07/04/09 09:10 PM
#362001
07/04/09 09:13 PM
07/04/09 09:13 PM
Jeepmon
Sunnyvale, CA
We love tyo play with the smoke machine
him too
That poor kid!!
[Re: Jeepmon]
#362002
07/05/09 10:14 AM
07/05/09 10:14 AM
Posts: 1,489 St. Louis Mo.
10 o to go
"Happy Don"
"Happy Don"
St. Louis Mo.
does it have evac pan system ,check ball valves ?crankcase pressure under load high rpm causes leaks . check breather caps some foam or wire mesh becomes loaded blocked see if dip stick creeps out under load . don
2009 418" build dan smith built
new 9.96 131.82
6.23 108
1.30 60 foot
best to date 9/15/09
8in 727 430 dana 2860 lb 3040 lb w driver
