What to do to make this hemi run 11.51?
#361926
06/29/09 08:00 PM
06/29/09 08:00 PM
Posts: 2,103 East Coast, NJ
fig426
East Coast, NJ
As some of you know, I've been sorting out the SS/DA Hemi Challenger. I found a World block which will be a 4.500 bore. I don't have a crank, rods, pistons, intake or cam. I'll be running stock cast heads with maybe some light port work. The car can't go faster than 11.5 because I don't want to put a roll bar in the car. It will weigh in about 3800 with me in it. Where do I go from here? Make it a 528? 572? Header size? Cam? etc.... I want to keep the dual quads with the shaker hood to keep it as close to the way it was as possible.
Chris from New Jersey
Re: What to do to make this hemi run 11.51?
[Re: Quicktree]
#361933
06/29/09 09:20 PM
06/29/09 09:20 PM
fig426
East Coast, NJ
As far as I know, the last time it was raced was 1975. Apparently the rules were a bit different back then?
[Re: fig426]
#361935
06/29/09 09:26 PM
06/29/09 09:26 PM
Quicktree
I started racing in 75 and im pretty sure they were required back then. maybe BG or somebody can varify that.
[Re: fig426]
#361938
06/30/09 07:29 AM
06/30/09 07:29 AM
Posts: 1,443 Maryland
Dads426
Maryland
A friend of mine ran a SS/DA 70 cuda in the mid 70's with a bolt-in 3-point Lakewood rollbar. Try that today...
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: fig426]
#361941
07/25/09 11:46 AM
07/25/09 11:46 AM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
Chris: This is what I would do... Use a stock replacement block, (unless you have the WP block already and are committed to using it). Put a 4.15 stroke crank and a solid roller or just a plain solid cam. Little port work on the heads and run a Rat Roaster and a pair of Competition series Carters. Set of TTI 2-1/4" headers. Should EASILY run the number, and you will have the Nostalgia look covered. I am fully aware that there are much better combos out there, this would really look cool on a car like your Challenger MB
[Re: HPMike]
#361942
07/25/09 11:55 AM
07/25/09 11:55 AM
chris, call alan , arc , i have a bunch of hemi parts left over to get you where you want to be, i know i got the crank and rods for you and a cam, not sure if you want to go hydralic or roller, but he'll get you where you want to be.
#361944
07/25/09 03:29 PM
07/25/09 03:29 PM
11.51...easy put a smallblock in it
