'67 Satellite Tear Down Questions
#361582
06/29/09 11:41 AM
06/29/09 11:41 AM
Posts: 1,379 Airdrie, AB
Mills
Airdrie, AB
Hey - wondering if you can help me out with a couple quick & easy ones...I'm in the process of ripping my car apart for a redo
1) Instrument Panel. I've got all the screws out the hold the panel in, and was hoping I could pull it out far enough to disconnect everything not laying on my back and swearing. It doesn't seem to want to move more then 1/2 inch (and seems like it swivels into place with the bottom first having some sort of flange). Is there a trick to this (i.e. mabe just the speedo cable needs to get disconnected first), or do I have to bite the bullet and swear?
2) Engine bay main bulkhead. Any tricks to disconnect? I've played with it a bit, not that much, but just want to make sure when I do finally attempt it for real, I'm not doing anything wrong that will break something.
Thx!
1967 Satellite, CNC Eddy Headed 500ci Street Mauler (Dyno'ed @ 600 HP / 650 ft-lbs)
2016 Challenger Hellcat - Holy Hell 2012 Hemi Ram Sport Crew Cab 2011 Avenger, Pentastar V-6 2007 SRT-8 Charger (Dyno'ed @ 470 RWHP) 1986 Caravelle, 318, aka "Rosco", Back Road Burner!
ALL Black...Bad Boys always wear Black!
Re: '67 Satellite Tear Down Questions
[Re: Mills]
#361586
06/30/09 11:56 AM
06/30/09 11:56 AM
Posts: 477 Clarkston,MI
Todd_DesMarais
super street
super street
Clarkston,MI
the connectors pop out fairly easy. squeeze and pull the engine side harnesses, then squeeze the clips and push the bulkhead in. might also want to warm up the plastic with a hair dryer. don't get it too hot to where it will melt, just enough to help make it pliable and soften any old dielectric grease. we know how cold it is up there 'eh. As for the instrument cluster, you might want/need to drop the steering column down an inch or so (sorry, 27mm or so) to allow it to come out of the dash without scraping the top of the column.
Todd
aduC' 47
IIeredevleB 66
383 etilletaS 66
DTC 0053 MAR 50
"ssenlli latnem a dna ,ybboh a neewteb enil enif a si ereht"
[Re: Todd_DesMarais]
#361587
07/03/09 01:03 PM
07/03/09 01:03 PM
Mills
Airdrie, AB
Thx for all the help...everything worked out perfectly. The instrument cluster was a PITA...seems I just couldn't get the right angle, but finally got it. It can be removed w/o disconnectng anything as there is enough play in everything to pull out and then disconnect. I think if the steering column was totally out (as it doesn't drop very far unless I'm doing something wrong) it would come out easier. Next qeustion, and the last thing really to be removed from the car (less engine and transmission as I need cherry-picker / help then is will be totally bare ready for body shop)...the brake booster. FSM makes it sound SO easy...well, I have to say they had to have put that thing in the car before ANYTHING else. I can't get on the passenger-side firewall nuts for the life of me. I finally got the bottom one, but the top is impossible. Have to go to the tool store and get another extension and universal...hopefully that does it. Just wondering if there is another trick to this? I will be converting over to manual brakes so hopefully going to just a master w/o the booster is going to be easier assembly wise.
