Distributor drive bushing backyard install??? #361392
06/28/09 11:27 PM
06/28/09 11:27 PM
Manitoba, Canada
DaytonaTurbo Offline OP
Manitoba, Canada
I hear the distributor drive bushings are supposed to be installed and burnished with a special tool. I have my 440 out right now for a backyard type refresh and I did buy a new distributor shaft bushing. I have no reason to believe mine really needs replacing but seeing as I'm in there anyway are there any reasonable backyard ways of installing the bushing without wrecking it or should I just leave my original bushing in there?
Re: Distributor drive bushing backyard install??? [Re: DaytonaTurbo] #361393
06/28/09 11:33 PM
06/28/09 11:33 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
I replaced the one in the 318 in my Power Wagon in my back yard. just used a piece of brass to tap it in. Piece of cake.
1981 Dodge D150 360 auto
Re: Distributor drive bushing backyard install??? [Re: DaytonaTurbo] #361394
06/28/09 11:46 PM
06/28/09 11:46 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Don't replace it if you don't have reason to.
Re: Distributor drive bushing backyard install??? [Re: goldmember] #361395
06/29/09 07:29 AM
06/29/09 07:29 AM
scratchnfotraction Offline
the last one I did on my sb,I just drove in with the oil pump shaft with the cam not in
then I installed the cam
dealer said no need to burnish them any more as the bushing has been changed to not need it
I was always told if it does not come out with the drive its fine and dont change it
I changed mine cause it came with the core plug kit
I have had no trouble so far
Re: Distributor drive bushing backyard install??? [Re: DaytonaTurbo] #361396
06/29/09 09:02 AM
06/29/09 09:02 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
If it's got the aluminum bushing, I'd replace it for sure. They are usually wallowed out.
Re: Distributor drive bushing backyard install??? [Re: scratchnfotraction] #361397
06/29/09 04:07 PM
06/29/09 04:07 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
If that is the case, why doesn't the burnishing tool pull out of the new bushings by hand instead of having to turn the nut with a wrench to pull the tool out of the bushing?
Re: Distributor drive bushing backyard install??? [Re: Snoopy] #361398
06/29/09 04:28 PM
06/29/09 04:28 PM
BRawls Offline
super gas
BRawls  Offline
super gas
On a BB, you can use an old oil pump drive to drive the bushing into the hole. This keeps the bushing from distorting and needing to be reamed. Done many motor this way and never had a problem.
Re: Distributor drive bushing backyard install??? [Re: Snoopy] #361399
06/29/09 04:37 PM
06/29/09 04:37 PM
some thing that the center hole was bigger and when drove in the block it squeezes the center hole to the right size
not saying its correct..just saying thats what the counter man said
I use the oil drive to drive them in also and never had a problem
Re: Distributor drive bushing backyard install??? [Re: scratchnfotraction] #361400
06/29/09 04:44 PM
06/29/09 04:44 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Having done probably 25 or 30 of these bushings myself, I can tell you that I've only had to burnish probably 8 or so.
They're usually pretty good....the one's that need burnishing WILL be noticably tight....so tight that the shaft will not go thru it unless you tap it vigorously. That's way too tight.
Most dealers have the tool....just be prepared to contribute to the "Coffee Fund"!!
Re: Distributor drive bushing backyard install??? [Re: scratchnfotraction] #361401
06/29/09 04:44 PM
06/29/09 04:44 PM
Snoopy Offline
Snoopy  Offline
I don't see a problem with the drive shaft installation technique, if the shaft turns easily by hand after the bushing installation.
Re: Distributor drive bushing backyard install??? [Re: scratchnfotraction] #361402
06/29/09 09:37 PM
06/29/09 09:37 PM
N
NITROUSN Offline
NITROUSN  Offline
N
I just did a dakota with mopar bushing and shaft and it had to be burnished.
Re: Distributor drive bushing backyard install??? [Re: DaytonaTurbo] #361403
06/29/09 09:45 PM
06/29/09 09:45 PM
Redwood City Ca.
B1arno Offline
B1arno  Offline
Redwood City Ca.
I've driven in 5 or 6 and never had a problem.
Arno
Re: Distributor drive bushing backyard install??? [Re: B1arno] #361404
06/29/09 09:59 PM
06/29/09 09:59 PM
IN
ahy Offline
ahy  Offline
IN
The shop that did my 440 didn't burnish. I had to take the engine apart for another reason and found the drive shaft scored and the bushing so loose it was almost spinning. I got a new bushing, new driveshaft and borrowed the burnish tool from a friendly dodge dealer. I had a near miss. I'd never do it or let it be done without the burnish tool again.
Re: Distributor drive bushing backyard install??? [Re: DaytonaTurbo] #361405
06/29/09 11:31 PM
06/29/09 11:31 PM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
Get rid of the aluminum and use the bronze bushing. It can be driven in as previously mentioned or "pulled" in. I use an old distributor drive as a pilot when I drive them in. I also have used a long piece of 3/8" all-thread with large washers and nuts on both ends. The nut on the bottom is used to draw(pull) it in.
