Page 6 of 8 1 2 3 4 5 6 7 8
Re: 64 Plymouth Fury project [Re: mopar rookie] #361212
11/26/10 06:35 PM
11/26/10 06:35 PM
central ohio
mopar rookie Offline OP
central ohio
Got the new dipstick with the locking top. It must be the wrong one cause it hits the ear on the tranny to where it wont bolt to the bellhousing. Its a 1965 tranny so does it need a special one or can i grind on that ear? Not sure what that ear is for.
Re: 64 Plymouth Fury project [Re: mopar rookie] #361213
11/26/10 06:45 PM
11/26/10 06:45 PM
central ohio
central ohio
Retaped the under the dash wiring and installed the dash. Installed the gauges and dash pad also. Took me forever to decide on the gauges. The only thing bad about the sun tach is you have to buy a 60.00 msd tach adapter if you run the msd ignition, which I am.
Re: 64 Plymouth Fury project [Re: mopar rookie] #361214
11/26/10 06:48 PM
11/26/10 06:48 PM
central ohio
central ohio
Im running a reverse shift valve body so I switched the buttons around so they would read correct.
Re: 64 Plymouth Fury project [Re: mopar rookie] #361215
11/26/10 06:51 PM
11/26/10 06:51 PM
central ohio
central ohio
New gas tank installed.
Re: 64 Plymouth Fury project [Re: mopar rookie] #361216
11/26/10 07:00 PM
11/26/10 07:00 PM
central ohio
central ohio
Got the windlace on the drivers side installed and the inner sillplate which gave me fits to get in there. The passenger side windlace is giving me problems cause when installed the door wont shut. Gonna have to get someone to help with that.
Re: 64 Plymouth Fury project [Re: mopar rookie] #361217
11/26/10 09:04 PM
11/26/10 09:04 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Just started reading your build post,,looking great,,,FYI,,I just had to buy a tach adapter for my old Sun,,$80.00+. Don't let that wreck your build budget!! Keep up the good work. I'll keep watching.
If you like drag racing, support your local track.
Re: 64 Plymouth Fury project [Re: CHAPPER] #361218
11/26/10 10:19 PM
11/26/10 10:19 PM
Funny, I'm getting ready to do the exact same thing! Man, I'm glad you posted that! I'm running an MSD 6AL and wouldn've been ticked to have to spend an extra $60 on an adapter.
I almost pulled the trigger on that tach and some Summit gauges pretty close to what you have but they have white faces and I'm not crazy about the "Summit" logo. BTW, what brand are the gauges in the pod?
Re: 64 Plymouth Fury project #361219
11/26/10 11:19 PM
11/26/10 11:19 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I was taking for granted, his was an older unit like mine. I was also under the impression, the NEW nostalgic looking Suns, ARE MSD compatabile(sp)??? Maybe I'm assuming too much! We all know what 'assume' does....anybody know for sure?? I had my older tach and wanted to use it for the 'period correct' look. After I hooked it up and it wouldn't work, I ordered the adapter. When I found out what it cost, I wasn't so sure I needed the look that bad. I had another tach that would have worked just fine as it had in the past.
Re: 64 Plymouth Fury project [Re: CHAPPER] #361220
11/27/10 01:00 AM
11/27/10 01:00 AM
central ohio
central ohio
That is the new sun tach but it does require the adapter. The other gauges are stewart warner that I got through Summit.
Re: 64 Plymouth Fury project [Re: mopar rookie] #361221
11/27/10 06:36 PM
11/27/10 06:36 PM
crlush Offline
crlush  Offline
Wow that car is turning out awesome! love the exteior/interior color combo.
Re: 64 Plymouth Fury project [Re: crlush] #361222
11/27/10 08:41 PM
11/27/10 08:41 PM
Vista, California
ChickMaggot Offline
ChickMaggot  Offline
Vista, California
That car is gonna be totally badazz.
You can lead a gift horse to water, but you
can't look in his mouth.
Re: 64 Plymouth Fury project [Re: ChickMaggot] #361223
01/06/11 07:15 PM
01/06/11 07:15 PM
central ohio
central ohio
Well I got back from picking up my exhaust manifolds from Aesthetic Finishers in Piqua Oh. They ceramic cast coated them and they look awesome.
Re: 64 Plymouth Fury project [Re: mopar rookie] #361224
01/06/11 07:16 PM
01/06/11 07:16 PM
central ohio
central ohio
Close up.
Re: 64 Plymouth Fury project [Re: mopar rookie] #361225
01/06/11 08:06 PM
01/06/11 08:06 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
She is a beauty, nice work
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: 64 Plymouth Fury project [Re: bigdad] #361226
01/18/11 09:00 PM
01/18/11 09:00 PM
central ohio
central ohio
Windshield and trim installed.
Re: 64 Plymouth Fury project [Re: mopar rookie] #361227
01/18/11 09:08 PM
01/18/11 09:08 PM
central ohio
central ohio
Got all of the inside chrome trim installed along with the sunvisers and rearview mirror.
Re: 64 Plymouth Fury project [Re: mopar rookie] #361228
01/18/11 09:23 PM
01/18/11 09:23 PM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
I just read through your thread. This car is coming out fantastic.
Scott
1969 Super Bee, 383/4 speed
Re: 64 Plymouth Fury project [Re: mopar rookie] #361229
01/18/11 10:12 PM
01/18/11 10:12 PM
Connecticut, USA
sixty7gtx Offline
sixty7gtx  Offline
Connecticut, USA
Before the car went to the body shop I steam cleaned the underneath of the car.
NICE Car:)
1967 Plymouth GTX,
1968 HEMI, 4 Spd. Super Bee,
2010 Chrysler 300 Touring,
MOPAR = Machines Of Performance And Racing!!
Re: 64 Plymouth Fury project [Re: sixty7gtx] #361230
01/18/11 11:41 PM
01/18/11 11:41 PM
midwest
68427vette Offline
68427vette  Offline
midwest
where in columbus are you? i'm in grove city.
Re: 64 Plymouth Fury project [Re: 68427vette] #361231
01/19/11 02:32 PM
01/19/11 02:32 PM
central ohio
central ohio
Hey Jeff, I'm actually north of Columbus between Mt. Vernon and Sunbury. Thanks guys for all the nice comments. I really need to start thinking about my motor next and who I'm going to have build it. Talked to a couple of different builders up in northern Ohio. Both seemed to be straitup honest guys. I just have to make up my mind who to go with
