70 E body seat belts? #360763
06/28/09 05:05 PM
06/28/09 05:05 PM
North Pole,New York
formula_s Offline OP
North Pole,New York
What years had the retractable belts? My drivers side doesn't want to retract. What years am I looking for?
Re: 70 E body seat belts? [Re: formula_s] #360764
06/28/09 05:30 PM
06/28/09 05:30 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Only the front belts on the door side retract.
Re: 70 E body seat belts? [Re: Snoopy] #360765
06/28/09 05:44 PM
06/28/09 05:44 PM
North Pole,New York
North Pole,New York
Yes, it goes down under the carpet hidden by that white plastic thing . My question is what other year ebodies have them?
Re: 70 E body seat belts? [Re: formula_s] #360766
06/28/09 06:28 PM
06/28/09 06:28 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
70 only, take it out & have a look at it, take the snap ring off & slide the pin back, it is holding a twisted spring so if the spring is broken it won't try to untwist.. I have found a few that broke right at the end, if that happens you can rework the spring, if it broke in the middle it's a parts seatbelt.. But some C bodies used the same design so you might find one of those....
Re: 70 E body seat belts? [Re: 1_WILD_RT] #360767
06/29/09 01:41 PM
06/29/09 01:41 PM
North Pole,New York
North Pole,New York
Took the snap ring off and pulled out the roller assy. The spring is not broken,Put it back together and it seems to be working. What year c bodies had the same setup??
Re: 70 E body seat belts? [Re: formula_s] #360768
06/29/09 05:04 PM
06/29/09 05:04 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Maybe 69 definately 70.. I got some really nice parts off a nice 70 Sport Fury that took a hard hit back in the early 90's
Re: 70 E body seat belts? [Re: 1_WILD_RT] #360769
06/29/09 05:26 PM
06/29/09 05:26 PM
North Pole,New York
North Pole,New York
OK thanks, I'll be looking for spare at Carlisle. One more question, are they different left from right?
Re: 70 E body seat belts? [Re: formula_s] #360770
06/29/09 05:31 PM
06/29/09 05:31 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Yes
FWIW If your looking for a spare you'll know visually if it's the one, they are the only two belts I've seen with the spring wrapped around a pin secured with a snapring... & the C body floor bracket is different so you need the E body bracket...
The Fact that Mike Ross (BEA is now reproducing these makes it a little easier.. Not cheap but his belts are super nice.. Not for the Concourse crowd but great for someone that wants it 95%+ visually correct & brand new...
Re: 70 E body seat belts? [Re: 1_WILD_RT] #360771
06/29/09 06:02 PM
06/29/09 06:02 PM
Snoopy Offline
Snoopy  Offline
Which one is a 70 E-Body and what does the other fit?
Re: 70 E body seat belts? [Re: Snoopy] #360772
06/29/09 06:10 PM
06/29/09 06:10 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I'd have to dig around in my junk, it's beem years since I played with them.. I think the E-body one is on the left... I'm assuming the other is C body but if theres another application give it up...
Re: 70 E body seat belts? [Re: 1_WILD_RT] #360773
06/29/09 06:19 PM
06/29/09 06:19 PM
North Pole,New York
North Pole,New York
The one with the raised boss on the left is for e bodies.
