Page 1 of 4 1 2 3 4
Eddy Victor vs. Indy EZ 325 vs. Indy 440-1 #360284
06/28/09 09:55 AM
06/28/09 09:55 AM
U.S.
moparniac Offline OP
U.S.
Fully ported and going into an a body... which would you choose for power 500-540 C.I range / Pump Gas 11-11.5 comp. and about .700 solid roller range......
Mopar Performance
Re: Eddy Victor vs. Indy EZ 325 vs. Indy 440-1 [Re: moparniac] #360285
06/28/09 09:58 AM
06/28/09 09:58 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
indy 440-1s
1.39 9.85 - 137 mph
Re: Eddy Victor vs. Indy EZ 325 vs. Indy 440-1 [Re: Ari440] #360286
06/28/09 10:07 AM
06/28/09 10:07 AM
do it right the 1st time ,get some B1's
but if thats not an option go 440-1 cnc ported .
Re: Eddy Victor vs. Indy EZ 325 vs. Indy 440-1 #360287
06/28/09 10:45 AM
06/28/09 10:45 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Are you gonna spend the 12-1500 on custom, big tube headers, or are you gonna try to get by with a set of BB-A headers you bought used in the for sale section??
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Eddy Victor vs. Indy EZ 325 vs. Indy 440-1 #360288
06/28/09 10:46 AM
06/28/09 10:46 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I have made over 850hp, with a set of Modern Cylinder Heads 440-1's and CNC ported work.
The track numbers dont lie
Re: Eddy Victor vs. Indy EZ 325 vs. Indy 440-1 #360289
06/28/09 10:51 AM
06/28/09 10:51 AM
nc
moeflo Offline
moeflo  Offline
nc
I couldn't agree more.
Not to fuel any rumors, just for my personal info, has anyone had any problems with recent Indy castings? (SR's, -1's)The last ones I did were years ago and they were heavily ported with zero problems. A friend of mine recently did little more than a clean-up and VJ on a new set and had a leak where he had removed no more than .020". On the earlier ones,and in the same place I had removed .100"+ with no issues.Just wondering if it was a fluke. I felt bad as I recommended them on the strength of the castings.
Re: Eddy Victor vs. Indy EZ 325 vs. Indy 440-1 [Re: moparniac] #360290
06/28/09 11:20 AM
06/28/09 11:20 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
While B1 will ultimately make more power, how much is your budget?
I have the -1's with home porting, 498 and with a .640 solid roller made about 720hp.
Re: Eddy Victor vs. Indy EZ 325 vs. Indy 440-1 [Re: moparniac] #360291
06/28/09 11:34 AM
06/28/09 11:34 AM
AndyF Offline
AndyF  Offline
The EZ heads will make plenty of power and the stock location exhaust ports might make it easier to find headers. The -1 heads have raised ports while the Victors have the ports moved up even more. The Victor heads require special rocker arms and they have some other funny stuff.
Any of those heads will make power, just have to work thru the list of pluses and minuses.
Re: Eddy Victor vs. Indy EZ 325 vs. Indy 440-1 [Re: AndyF] #360292
06/28/09 11:52 AM
06/28/09 11:52 AM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
Hindsight is always 20/20 but I wish I had gone with the 325-1's on my build. I am close to 700 hp with my lowly 295-ez's though.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: Eddy Victor vs. Indy EZ 325 vs. Indy 440-1 [Re: moparniac] #360293
06/28/09 11:55 AM
06/28/09 11:55 AM
an8sec70cuda Offline
What headers do you have now? With B1's you'll need custom headers made which can be expensive. Personally, I'd go with the CNC'd 440-1 heads if I didn't have the budget to build a B1 or Hemi. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Eddy Victor vs. Indy EZ 325 vs. Indy 440-1 [Re: an8sec70cuda] #360294
06/28/09 12:02 PM
06/28/09 12:02 PM
Houston, Texas
Houston, Texas
"if I didn't have the budget to build a B1 or Hemi. CHIP"
Ya, all of us are not as fortunate as you are to be able to have a low 9 second street car!
Re: Eddy Victor vs. Indy EZ 325 vs. Indy 440-1 [Re: moparniac] #360295
06/28/09 12:11 PM
06/28/09 12:11 PM
NC
440Jim Offline
440Jim  Offline
NC
Of the choices, 440-1. Get them CNC ported, good rockers (not Indy), and for that CID at least 2-1/8" headers. Avoid the Hooker Super Comp fenderwell headers, 2" x 43" long...
Yes B1 original heads ported will make more power.
Re: Eddy Victor vs. Indy EZ 325 vs. Indy 440-1 [Re: an8sec70cuda] #360296
06/28/09 12:28 PM
06/28/09 12:28 PM
U.S.
U.S.
the money is there.... just not totally sure chip I forgot to mention I would love to try and stay with the under chassis headers not the spider ones but will If I have to...
Mopar Performance
Re: Eddy Victor vs. Indy EZ 325 vs. Indy 440-1 [Re: moparniac] #360297
06/28/09 12:34 PM
06/28/09 12:34 PM
U.S.
U.S.
I forgot to mention..... I wanna run in the 9's ALL day long on motor and any heat is my goal meaning I dont want a 10.2 car and in october run a 9.90.... hope this helps..... I also have been thinking about a B1 setup... just trying to find the simplest setup to stuff into an A body car...
I have seen some of your b1 pics and some of you have braided lines in front of the heads going down into the block or something...
Mopar Performance
Re: Eddy Victor vs. Indy EZ 325 vs. Indy 440-1 [Re: MoparBilly] #360298
06/28/09 12:35 PM
06/28/09 12:35 PM
U.S.
U.S.
If I have to I will
Mopar Performance
Re: Eddy Victor vs. Indy EZ 325 vs. Indy 440-1 [Re: 67HEMI] #360299
06/28/09 12:38 PM
06/28/09 12:38 PM
U.S.
U.S.
10.2 at 3800lbs I would think you were making more than 700 at the crank...
Mopar Performance
Re: Eddy Victor vs. Indy EZ 325 vs. Indy 440-1 [Re: moparniac] #360300
06/28/09 12:40 PM
06/28/09 12:40 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
9.90 at what weight? any of those heads will do that with 540 ci. Do you have a short block already? Decide from that.
Re: Eddy Victor vs. Indy EZ 325 vs. Indy 440-1 [Re: AndyF] #360301
06/28/09 12:42 PM
06/28/09 12:42 PM
U.S.
U.S.
thats exactly what Im thinking andy...
Mopar Performance
Re: Eddy Victor vs. Indy EZ 325 vs. Indy 440-1 [Re: cudabunch] #360302
06/28/09 12:43 PM
06/28/09 12:43 PM
U.S.
U.S.
I was assuming an A body was 3300-3400 with a BB Race weight
I have had several quotes on short blocks and complete engines .... just trying to decide... the money is there.... decisions decision..
I dont wanna waste as much money as I did on my challenger build... however I did get almost $30k for a 72 challenger with a busted up front end
Mopar Performance
Re: Eddy Victor vs. Indy EZ 325 vs. Indy 440-1 #360303
06/28/09 12:57 PM
06/28/09 12:57 PM
U.S.
U.S.
just curious but what do cnc'd indy-1s flow @ .700 lift
Mopar Performance
Page 1 of 4 1 2 3 4
