v-8 in a 52 dodge business coupe #360182
06/28/09 12:09 AM
06/28/09 12:09 AM
little rock, iowa
K
ken65 Offline OP
super street
ken65  Offline OP
super street
K
little rock, iowa
anyone have pics or suggestions on what i need to do to put a 318 with an automatic into my 52 dodge business coupe? any help would be great.
Re: v-8 in a 52 dodge business coupe [Re: ken65] #360183
06/28/09 11:27 AM
06/28/09 11:27 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Yes, take a look at this site for a lot of info you will need and how that flatty might be the way to go.
http://www.50plymouth.com/02-hom/home.html
For the skinny on the swap, the old article, and how one guy did his whole car, this is the best I've found.
http://shadowmtkustomz.blogspot.com/
Things to consider:
Wiring = 6V positive ground to 12V negative ground.
Brakes = double the HP and you should upgrade the brakes.
Cooling = make sure you have enough to make all that hard work live.
There is a lot of info here too. Wade through the older posts.
Re: v-8 in a 52 dodge business coupe [Re: RodStRace] #360184
06/29/09 07:08 PM
06/29/09 07:08 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Didn't MP sell a "kit" to put an LA into this model.
Don't be the exception.
Re: v-8 in a 52 dodge business coupe [Re: Supercuda] #360185
06/29/09 08:54 PM
06/29/09 08:54 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
They did sell a "kit" to install a V8 in a FWD, and they have various parts to swap stuff around in 60s-up stuff, but I've never seen or heard of early swap parts. The closest they got was the street rod manual I asked about early this year. The guy still is selling copies.
http://cgi.ebay.com/ebaymotors/THE-MOPAR...1QQcmdZViewItem
Re: v-8 in a 52 dodge business coupe [Re: RodStRace] #360186
06/30/09 08:55 PM
06/30/09 08:55 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
It was several years ago, a "universal" kit to put an LA into a 48-52 ish MoPar, basically a repackaged kit from a more common street rod shop. It was, essemtally, a cut to width engine crossmember with ears for spool mounts.
Not real sophisicated.
