Re: alternator wiring questions
[Re: jensenguy]
#359847
06/27/09 05:50 PM
06/27/09 05:50 PM
Posts: 25,877 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If one of the field wires is wired directly to the battery you'll wind up with as dead battery, the field needs to be energized by the ignition switch.
Either field wire can be attached to either field terminal on the alternator, makes no difference.
[Re: jensenguy]
#359848
06/27/09 06:41 PM
06/27/09 06:41 PM
Im working on wiring up the alternator to my 440. I believe it is a 60amp (the smaller one) dual field. I think its from a 73 demon or something like that. The wires in my car arent the standard blue and green (big suprise right!) so Im trying to figure out which wires go where.
I have a white wire that goes to the regulator, and I have a heavy brown wire that loops directly to the Battery connection on the alternator.
I can figure that the green wire should go to the white wire. But all the diagrams I see are saying that the blue wire should be Ignition On voltage. Will that work if I hook that directly to battery voltage like it was previously wired? I really dont see why it wouldnt.
And for my final question, can someone tell me which leads on the back of the alternator go to green and blue? Ive found conflicting stories on the internet so Im really unsure now.
thanks!
WHAT A MESS
FIRST What kind (as in year/ model) is your car?
SECOND Why DOESN'T it have standard wire colors? Have you re--wired it?
THIRD WHAT year is the regulator, THAT IS are you using a 69 and earlier, or the 70 and later????????????????????????????????????
