426 Hemi manifolds and starters #359515
06/27/09 12:06 PM
06/27/09 12:06 PM
Chilliwack B.C. Canada
RUNCHARGER Offline OP
Starter is pooched in my 472. What starters do you guys use with stock 426 Hemi manifolds? I'd like to use a newer Chrysler starter but I don't know if the connections on it rub the manifold or not. Aftermarket is okay if there is something that will last longer than a plane ride to China.
Sheldon
Re: 426 Hemi manifolds and starters [Re: RUNCHARGER] #359516
06/27/09 12:28 PM
06/27/09 12:28 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I run the PowerMaster Chrysler minis,.....never had a failure/problems,....Summit $200
FYI,...trim the top post main terminal, A little to long, very close to the block, other than that spins it over no problem, no heat soak problems either
Re: 426 Hemi manifolds and starters [Re: DAYCLONA] #359517
06/27/09 09:02 PM
06/27/09 09:02 PM
PA
Jack Zupan Offline
Jack Zupan  Offline
PA
I don't think the PowerMaster has a piece to position the starter to the bellhousing indexing hole. How do you line one up to engage properly.
