72 challenger question #359503
06/27/09 12:05 PM
06/27/09 12:05 PM
so cal,cali
calimoparguy Offline OP
so cal,cali
On a 72 340 challenger,should there be an radiator overflow bottle or did they not have them?????
Re: 72 challenger question [Re: calimoparguy] #359504
06/29/09 07:45 AM
06/29/09 07:45 AM
Morningside, Long Island
scatcity Offline
scatcity  Offline
I don't believe it was offered in 72, the early part anyway. 73 there was one as well as 74. I have a 72 Chally as well and put one on. Mine was somwhat awkward though. I have a 22" radiator and the brackets that holds the shroud on didn't allow me to mount it where it "should" go, in between the battery and the radiator. So, I mounted the bottle, minus the bracket on the right side, in between the windshield washer resevior and the radiator. It's not correct for the purist, but it looks and fits fine and I personally like the luxury of having the overlow bottle. I used the offset bracket that mounts the original 73-74 bracket up top and the tabs on the overflow bottle for mounting it to the rad support line up perfectly. I'll shoot a few pics and forward. If you have a 26" rad support it should fit perfectly in the correct spot. Make sure if you buy the bracket that it has the offset mounting piece that supports the bottom bracket to the rad support.
Re: 72 challenger question [Re: scatcity] #359505
06/29/09 02:16 PM
06/29/09 02:16 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
I have a 73 Challenger that I've owned since it was 6 mos. with 6000 miles, and still under warranty. It did not come with an overflow bottle. It has the rubber hose running from the radiator filler neck, across the top of the rad. tank on the drivers side, and then runs down the side of the tank, where the overflow would empty onto the ground.
Re: 72 challenger question [Re: 318 Stroker] #359506
06/29/09 03:21 PM
06/29/09 03:21 PM
scatcity Offline
scatcity  Offline
Alright then. Maybe a 73 doesn't have the bottle but he's asking about a 72....
Re: 72 challenger question [Re: scatcity] #359507
06/29/09 03:28 PM
06/29/09 03:28 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
Re: 72 challenger question [Re: 318 Stroker] #359508
06/29/09 06:47 PM
06/29/09 06:47 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
72 DOESNT HAVE one, only on e bodies in 1974
Re: 72 challenger question [Re: 318 Stroker] #359509
06/30/09 05:31 AM
06/30/09 05:31 AM
scatcity Offline
scatcity  Offline
And not to get off topic, but how is your 6K mile 73 Challenger still under warranty??? I couldnt resist. And PS, I'm shooting the pics of the bottle today. And if you need the bracket I have an extra one.
Re: 72 challenger question [Re: calimoparguy] #359510
07/01/09 05:57 AM
07/01/09 05:57 AM
scatcity Offline
scatcity  Offline
Here's a bottle in a my 72 with a 22" radiator.
Re: 72 challenger question [Re: scatcity] #359511
07/01/09 06:58 PM
07/01/09 06:58 PM
scatcity Offline
scatcity  Offline
1 more attempt with an overflow with a 22" radiator picture..
Re: 72 challenger question [Re: scatcity] #359512
07/01/09 06:59 PM
07/01/09 06:59 PM
scatcity Offline
scatcity  Offline
shocker!!!!!!!
Re: 72 challenger question [Re: scatcity] #359513
07/01/09 09:38 PM
07/01/09 09:38 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
thats an a body over flow can.
Re: 72 challenger question [Re: 05dakota] #359514
07/01/09 09:53 PM
07/01/09 09:53 PM
scatcity Offline
scatcity  Offline
Negative on the A Body, It's an E body tank, one of 4 I have. Maybe it just looks like an A body one cause it's on the wrong side and in the wrong year car?
