Page 1 of 3 1 2 3
Broke 727 Tailshaft... Why? #359389
06/27/09 11:03 AM
06/27/09 11:03 AM
Danville, NH
Mopar_Mike Offline OP
Danville, NH
Went to check out a small trans leak and low and behold see the crack around tailshaft. Starts at the speedo cable and up and around..
What could have caused this?
67 Coronet 3800#, 500hp 440, 727 with 3300-3500 stall. I put about 15 runs on the car so far this season. I have solid engine mounts and the poly trans mount.
This Sux..
RS23L7 4-Speed
Re: Broke 727 Tailshaft... Why? [Re: Mopar_Mike] #359390
06/27/09 11:10 AM
06/27/09 11:10 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Your rear bushing in the tail shaft may have been worn and allowed vibration and or your yoke may be a bit to far out (too short of a drive shaft) I broke a couple before I went and got a new drive shaft made and not a problem since. only about 3/4" to 1" longer but made a huge difference.
Changing some things in your rear suspension can affect drive shaft length
Re: Broke 727 Tailshaft... Why? [Re: Mopar_Mike] #359391
06/27/09 11:14 AM
06/27/09 11:14 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If your car has alot of flex in it the poly mount
could be too stiff, 3/4" max for the drive shaft
movement... they tend to break where your did... thats
the weak point in the tail shaft... also make sure
the drive shaft isnt bottoming out in the trans...
do you have engine limiters
Re: Broke 727 Tailshaft... Why? [Re: MR_P_BODY] #359392
06/27/09 11:29 AM
06/27/09 11:29 AM
Danville, NH
Danville, NH
The only vibration I feel is just before I hit the traps. But I am thinking it is just suspension/wheel balance... ?
I am about to pull the driveshaft, I will check to see if it bottoms out, but I am not sure I understand the play?
...Also, I was foot braking the car and held it back to around 3200-3300 rpm and then would launch the car. Think maybe I torqued it too much and it broke that way?
RS23L7 4-Speed
Re: Broke 727 Tailshaft... Why? [Re: Mopar_Mike] #359393
06/27/09 11:39 AM
06/27/09 11:39 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Bottom out the shaft in the trans, then when you pull
it back to mount it on the diff you shouldnt have
more than 3/4" movement.... but if its too long you
could be bottoming out in the trans(as the rearend
gets closer to the same level the drive shaft is
getting pushed into the trans)
Re: Broke 727 Tailshaft... Why? [Re: Mopar_Mike] #359394
06/27/09 11:44 AM
06/27/09 11:44 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
The vibration I felt was breaking mine new longer driveshaft fixed that.
with solid mounts it should not move front to back like on elephant ears?
hears a dimensions picture
Re: Broke 727 Tailshaft... Why? [Re: Dodgem] #359395
06/27/09 11:44 AM
06/27/09 11:44 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
never took?
Re: Broke 727 Tailshaft... Why? [Re: Mopar_Mike] #359396
06/27/09 11:50 AM
06/27/09 11:50 AM
ky
68roadrunner Offline
ky
i broke one when i switched to a dana and the shaft was bottoming out. i was told that when tieing one down not to pull the rachet strap against the parking brake, it could crack it, im not for sure on that one. good luck
Re: Broke 727 Tailshaft... Why? [Re: 68roadrunner] #359397
06/27/09 12:43 PM
06/27/09 12:43 PM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
my dad had a problem when he would lift after the stripe it would break the trans . he tried mounts , shafts, shocks and a ton of other things. he went through 4 housing . new leaf springs fixed the problem. its getting to the point where age HAS to be considered on parts, if they are beat on or not
Re: Broke 727 Tailshaft... Why? [Re: mcat4321] #359398
06/27/09 01:45 PM
06/27/09 01:45 PM
Mobile Al
Dale Offline
Dale  Offline
Mobile Al
I had a bent output Shaft do the same thing so chech it for run out.
Re: Broke 727 Tailshaft... Why? [Re: mcat4321] #359399
06/27/09 02:56 PM
06/27/09 02:56 PM
Indiana
65dragnet Offline
65dragnet  Offline
Indiana
That is usually caused by by pinion angle being wrong
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Re: Broke 727 Tailshaft... Why? [Re: 65dragnet] #359400
06/27/09 03:00 PM
06/27/09 03:00 PM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
the set pinion angle had nothing to do with it.
going from under heavy load to relaxed had the pinion moving because of the front of the spring being shot , it would let the rearend yolk move up and down too much.
Re: Broke 727 Tailshaft... Why? [Re: mcat4321] #359401
06/27/09 03:19 PM
06/27/09 03:19 PM
Q
Quicktree Offline
Quicktree  Offline
Q
pinion angle has everything to do with it what the heck do you think happens when the rearend yoke moves up and down to much?
Re: Broke 727 Tailshaft... Why? [Re: Quicktree] #359402
06/27/09 03:56 PM
06/27/09 03:56 PM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
thats why i put the "set" pinion angle.. changing it with shims or rewelding the perch would not stop the problem. the leafs was the problem.. thats like saying running over a chunck of steel didnt cause the wreck, the flat tire did..
Re: Broke 727 Tailshaft... Why? [Re: mcat4321] #359403
06/27/09 05:19 PM
06/27/09 05:19 PM
Stratford,Ct
7sec.cuda Offline
7sec.cuda  Offline
Stratford,Ct
wrong pinion angle or drive shaft is to long
Re: Broke 727 Tailshaft... Why? [Re: 7sec.cuda] #359404
06/27/09 10:35 PM
06/27/09 10:35 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I agree with not enough nose down on the pinion. All the stock perches I've seeen never have enough. Your lucky if you have 1 degree down. My buddys 10.80 GTX and another friends 65 Belvedere both broke a few tail housings. Cut the perches off and rewelded them 5 degrees down, problem solved. My 11 seconnd Volare has never broken one. It's been at 5 degrees since its been raced starting in 1990. The drive shaft bottoming out will break it as well and should be verified for clearance.
Doug
Re: Broke 727 Tailshaft... Why? [Re: dvw] #359405
06/27/09 10:45 PM
06/27/09 10:45 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I saw one cracked a few months ago,the govenor lost a clip allowing it to slide out of it's bore and breaking the tailshaft housing.
Re: Broke 727 Tailshaft... Why? [Re: dvw] #359406
06/28/09 06:08 AM
06/28/09 06:08 AM
Danville, NH
Danville, NH
Doug
It is a stock 8 3/4 axle housing with stock perches. It is a 742 case with MW spool. When I bought the car it had a 7290 differential joint. I am not sure what brand it was, could have been stock. I did purchase a different (lighter/stronger) 7290 joint when I had the center rebuilt. I suppose it is possible the length of the joints was different...?
RS23L7 4-Speed
Re: Broke 727 Tailshaft... Why? [Re: 7sec.cuda] #359407
06/28/09 08:12 AM
06/28/09 08:12 AM
metro detroit
turner Offline
turner  Offline
metro detroit
I broke my tail shaft housing, due to an incorrect pinion angle, mine broke on the finish line after I got out of the throttle, I believe my driveshaft was too short and pulled out of the trans too far.
Re: Broke 727 Tailshaft... Why? [Re: Mopar_Mike] #359408
06/28/09 09:16 AM
06/28/09 09:16 AM
wappinger falls new york
Jimi_Vignogna Offline
it is the poly rear mount that caused it you cannot do that with solid engine mounts you need a solid rear trans mount.
Page 1 of 3 1 2 3
