TQ question #359365
06/27/09 10:27 AM
06/27/09 10:27 AM
ILLINOIS
V
volaredon Online content OP
volaredon  Online Content OP
V
ILLINOIS
Finally got around to reassembling one of my T-Q's last nite. that I had Demonsizzler re bush for me about 6 weeks ago. Got overheated a bit outside, so this was was a "nice" cool down job at the kitchen table in the A/C!
(note to self; go order the kit for the other one before all the important "little" parts get lost!)
Anyway, what I need to know, is that I also got a set of real brass floats from him. There is not alot of difference between specs here; but in the kit I got by application for these carbs, it appears that all call for a 29/32 float height; a couple say 27/32; but I found an old "tech-lit" instruction sheet (the ones that are packaged with all the carb kits) folded up in one of my FSM's; different years were covered, and both BB and SB applications.
Now in this older spec sheet (neither listed many 318 apps, but the ones that did were basically the same spec as some of the 440 application specs) The older sheet listed more by engine CID, the newer one was more by carb number.
Orig app for both my carbs, was '80 truck 360; carb #'s are 9265-S; but I am putting one on an '83 318 with EQ heads, stock replacement 360-2 cam, (think Comp 252) Performer intake, hooker headers and duals.
So, being that I am not using these carbs on their OE intended application, AND apparently they did not have brass floats as OE during the years the kit I bought covers, what should I set them at?
The older spec sheet shows several at 1", a couple at 1-1/16; but all but 1, that showed 1"/1-1/16" float spec in that older sheet, also had a footnote saying that if using non brass floats, to use 29/32; same as all the factory service manuals I have here with a T-Q section do;
Is it safe to "assume" that the reverse is also true, when it says to use a different spec for non brass floats? I set it up at 1-1/16" being brass, and also being only a 318. It would be easier to go back and change now than once it is on my truck.
Re: TQ question [Re: volaredon] #359366
06/27/09 11:52 AM
06/27/09 11:52 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: TQ question [Re: Rug_Trucker] #359367
06/27/09 12:00 PM
06/27/09 12:00 PM
scratchnfotraction Offline
Re: TQ question [Re: scratchnfotraction] #359368
06/27/09 03:27 PM
06/27/09 03:27 PM
ILLINOIS
V
V
ILLINOIS
thanks for the I need an answer before I bolt this thing on.
Re: TQ question [Re: volaredon] #359369
06/27/09 06:26 PM
06/27/09 06:26 PM
Stone Mt, GA.
DEMONSIZZLER Offline
super gas
super gas
Stone Mt, GA.
Just an fyi, I set all floats, brass or nytrophyl, on all T.Q. models except for smogger carbs that have to pass emissions, to 29/32". All current replacement brass floats regardless of application/model, set to 29/32" according to the mfg, David.
ThermoQuads:stock, street/strip and race; 800/850 cfm's, 860/910 cfm's and 1,000 to 1,060 cfm's. New parts for all OEM 1971-1984, Competition Series and SuperQuad carbs and custom fabricating. Carbs bought and sold. Consulting on pre-purchases so you get the right carb the first time.
Re: TQ question [Re: DEMONSIZZLER] #359370
06/27/09 07:42 PM
06/27/09 07:42 PM
ILLINOIS
V
V
ILLINOIS
I was hoping that you'd chime in here Dave; these are not "new" replacements but some of your "good/used" ones; the different specs were for the older mid 70s carbs with the brass ones being spec'd at lower readings. Being that emissions regs got tighter as the years went on, the regs were definitely "looser" in the brass float days; what would the difference be, to cause a carb kit parts maker (or just seller?) to show a different spec for the same carb with floats made of different materials? Were they allowing for some "soak-up" of gas, where that would make the plastic floats wanna hang naturally lower?
