I'm building a new motor and getting ready to order a set of stage V heads. In specifying the springs which are for a Hydraulic roller cam the supplier had nothing but bad news on using the HR cam due to the higher push rod pockets in the lifters. He said the geometry is so bad that the heads need to be cut and the valves are guaranteed to float below 6000.... I had Crane (before they folded) design and send me the cam; it is HR-236/359-14 grind (lift .564/.546, dur @.050 236/236, springs 144# closed / 375# @1.36"). It is a turbocharged project.
Does anyone have HR experience with the HEMI's?
Tom
