Zeus Fastener #358887
06/26/09 06:23 PM
06/26/09 06:23 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
How many fastener are u fellas are using on you'r e-body fiberglass hoods and were.I were thinking(4) down each side (4) on the front.Do u all put zeuss on the rear of you'r hoods? Thax. Pic's would be nice....
Re: Zeus Fastener [Re: racerx] #358888
06/26/09 06:55 PM
06/26/09 06:55 PM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
This is what I did:
Re: Zeus Fastener [Re: PolyDart] #358889
06/26/09 07:21 PM
06/26/09 07:21 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Thax... ab7fh I see u are running (2) in the front/back (3)on each side.I'm thinking (4)on the e-body (each side)because the length of the hood.
Re: Zeus Fastener [Re: racerx] #358890
06/26/09 07:30 PM
06/26/09 07:30 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
put as many as you can afford to spread the load. i originally mounted my 1 piece front clip on with zues clips but the vibrations & distortion of the body under power would allow them to pop off & at 3/4 track the front was lifting off allowing me to see the engine. i now use pins which are so much more reliable & have never had one come off since.
my rear hatch is still zues clipped on but i cover the clip with race tape to prevent them popping up. good luck with your project.
Re: Zeus Fastener [Re: racerx] #358891
06/26/09 07:40 PM
06/26/09 07:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Someone had a pic of a black E-body at PRP at the
CC race and the front of that hood had a BIG gap in
it at speed..... you need at least 2 zues fasteners
in the front... maybe 3 just to hold the front down.
I have 5 down each side on my car.... use to have
2 at the rear near the edge of the scoop but I now
use a separate scoop that has 3 zues fasteners just
for the scoop then the hood holds the scoop down also
Re: Zeus Fastener [Re: racerx] #358892
06/26/09 08:23 PM
06/26/09 08:23 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
About this many to keep the air out and make your glass last !!!!
Re: Zeus Fastener [Re: Chassisman] #358893
06/27/09 11:00 PM
06/27/09 11:00 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Thax.... 4 the replies
Re: Zeus Fastener [Re: racerx] #358894
06/27/09 11:05 PM
06/27/09 11:05 PM
Four in the back, four in the front as close to the front edge of the hood as you can get and three or four , depending on the length of the hood,down each side
Re: Zeus Fastener [Re: Cab_Burge] #358895
06/28/09 03:33 PM
06/28/09 03:33 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Dzus.
You can get them in different lengths to accomodate the wire retainer location (distance from panel), but you're better off having the bracket fairly tight against the panel.
On my car I used a piece of 1 x 1/2 aluminum angle to support the hood & keep it straight (my hood's quite thin).
Re: Zeus Fastener [Re: topside] #358896
06/28/09 05:07 PM
06/28/09 05:07 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
And use the butterfly type so if someone need to get the hood off.If something go wrong they can..
I seen two cars now get the hoods burn off because no one had a tool to get them released.
Re: Zeus Fastener [Re: VernMotor] #358897
06/29/09 12:40 AM
06/29/09 12:40 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
theres a tool? hmmm we just use a small coin
Re: Zeus Fastener [Re: rebel] #358898
06/29/09 02:03 AM
06/29/09 02:03 AM
Me too
Re: Zeus Fastener [Re: Cab_Burge] #358899
06/29/09 08:25 PM
06/29/09 08:25 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
This may/may not be a stupid ?Do u use aluimin or steel rivets in you'r glass hoods? Thax...
