What do you guys think of this updated pic #358694
06/26/09 03:00 PM
06/26/09 03:00 PM
Athens,Ga
mjk5thave Offline OP
Athens,Ga
I'm working on my car and found this LOL . I knew the car had been hit after I bought it for $100.00 and it's not going to be a show car.
What do you guys think more spot welds . I do have a mig to do welding with or should I glass it back up and forget about it.I hope the shop that did the work is out of bussiness. The reason for removing all the filler from before is theres 6 layes or paint and primer with rust under it. You would think the car was painted atleast once a year with all that paint. thanks for the input
Mark
Re: What do you guys think of this [Re: mjk5thave] #358695
06/26/09 03:14 PM
06/26/09 03:14 PM
Ohio
LS-300 Offline
LS-300  Offline
Ohio
My is since you have started into it I would try to fix their screw-up and do right. Weld what I had to and make sure it stays away for a long time. I don't mind working on my cars but I prefer to drive them. If you get it right the first time you don't have to waste as much time down the road.
1979 Chrysler 300 1968 Barracuda project
Re: What do you guys think of this [Re: LS-300] #358696
06/26/09 06:46 PM
06/26/09 06:46 PM
Athens,Ga
Athens,Ga
bump
Re: What do you guys think of this [Re: mjk5thave] #358697
06/26/09 07:19 PM
06/26/09 07:19 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Filler will crack if put over a seam that is only spot welded. Must be welded solid. Of course you cant weld a continuous bead or you will warp the crap out of it.
Re: What do you guys think of this [Re: forphorty] #358698
06/26/09 08:52 PM
06/26/09 08:52 PM
Athens,Ga
Athens,Ga
yea I know I'll probly do about 1 inch then jump to another area probly take 1/2 of day to welder up. I'm kinda suprised it didn't crack before now but also not sure ow long it's been repaired eather it had about 3 layers of paint and primer each on it. it's been painted several times LOL
Re: What do you guys think of this [Re: mjk5thave] #358699
06/26/09 09:29 PM
06/26/09 09:29 PM
Georgia
PoisonDart Offline
super gas
PoisonDart  Offline
super gas
Georgia
Which car is this your working on? the 5th or the Mirada? the Mirada might be worth the time and effort to do it right although as you stated your not going for show quality, and the deeper you dig the more worms you may find,could add up to some serious $$$$$ I would make the easy repair by welding it back up fiberfill back over,
Re: What do you guys think of this [Re: PoisonDart] #358700
06/26/09 10:41 PM
06/26/09 10:41 PM
The Dalles, OR.
Dusted_Ya Offline
Dusted_Ya  Offline
The Dalles, OR.
Uh that looks like my quality of body work...
Re: What do you guys think of this [Re: Dusted_Ya] #358701
06/26/09 10:59 PM
06/26/09 10:59 PM
Athens,Ga
Athens,Ga
So far this is the biggest problem the rest of the car is nothing to get into shape> I guess I'll be welding for a few hours tomorrow hee hee hee and glassing it back up with a little less filler I hope but you never know.
Thanks for the replys guys
Mark
Re: What do you guys think of this update pic [Re: mjk5thave] #358702
06/28/09 08:41 PM
06/28/09 08:41 PM
Athens,Ga
Athens,Ga
updated pic from over the weekend.
I'll be glassing it back up in the next few days thanks for the replys
Mark
